Like I said, Canada has to have their own governing body, but I have no idea who it is or what their name is.zero_coke said:That is great sir! Thank you for the reply. Wookie's signature also noted. Thanks again.
Bill_Marsden said:Wookie's signature puts it best...zero_coke said:Hey Bill,
I was wondering why the Feds would show up at your door if you play around with some frequencies? I saw you mention it somewhere to be careful when doing such experiments, but can you please tell me more about it? I'm working on the witricity project, but I don't think I will be using radio frequency radiation, but its more like using magnetic fields and magnetic field radiation. Please correct me if I'm wrong. My current circuit consists of a
signal generator,
two coils,
two capacitors,
1 LED
I have the signal generator in parallel with the coil and the capacitor, and from the formula I found out their resonant frequency (f = 1/2PI*root(LC)), which was around 10 MHz. Could I get into trouble for this?
Thanks Bill!
I will say this, as long as it is magnetic coupling you are OK, but if you broadcast as RF you will be running into trouble. It is usually very hard to create one without the other, but it can be done.General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
FCC specs state you may not broadcast more than 10 mw RF power or have an antenna greater than 10 feet. I don't know what Canadian specs are, or the governing authority they use, but I'll bet it is something similar.
The main difference is a magnetic field doesn't radiate. It's just there.Question is the title of the thread.
Even fluxing fields? I've been curious exactly how you could separate the two.The main difference is a magnetic field doesn't radiate. It's just there.
eric
From what I understand you don't.Even fluxing fields? I've been curious exactly how you could separate the two.
