What's the damage threshold power for a signal generator?
Discussion in 'General Electronics Chat' started by Matjelo Naleli, Jul 18, 2016.
  1. Matjelo Naleli
    Oct 7, 2015
    39
    I have a Tektronix AFG3102 function generator with 50 Ohms output resistance and I want to drive a 5 Ohms load with it. Obviously the impedances are not matched and back-reflected power is inevitable. I could build a matching network but I just curious as to how much back-reflected power can this Function generator handle before it's damaged. I checked the manual but I couldn't get the info on this issue.
    Does any one know how much back-reflected power a typical function generator can tolerate?
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    The signal generator should be able to run into a dead short, that's as bad a mismatch as it gets.
    Otherwise there would be piles of dead signal generators everywhere...
  3. Matjelo Naleli
    Oct 7, 2015
    39
    Alright thanks Sensacell, I didn't know that.
  4. Kjeldgaard
    Member
    Apr 7, 2016
    73
    17
    An excerpt from the Datasheet:
    Output impedance: 50Ω
    Load impedance setting: Selectable: 50Ω, 1Ωto 10.0 kΩ ,HighZ
    Isolation: 42 V pk maximum to earth
    Short-circuit protection: Signal outputs are robust against permanent shorts against floating ground
    External voltage protection: To protect signal outputs against external voltages use fuse adapter 013-0345-xx
  5. #12
    Nov 30, 2010
    16,705
    7,358
    I smoked the 47 ohm resistor on the output of my EICO 390 signal generator many years ago.
    I don't know how I killed it, but it's possible.
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    Including both of mine. :)
