What's the best/preferred way to post a long project?
Discussion in 'Off-Topic' started by strantor, Jan 3, 2014.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    I am ever so slowly gearing up to start working on my dad's prosthetic hand project, which will probably take a year or more to see through to fruition. I anticipate that I might venture into uncharted territory in the arena of DIY prosthetics, and I would like all of my work to be on public record. Open source, in hi-res detail; not only source files. I would like to keep a chronicle of my progress, how I did what, at the time that I did it. I want people to know what I was thinking when I did what I did so that they can come up with a better idea. Also, that way I don't have to go back a year or two later and construct a retroactive "who to build a prosthesis" tutorial since I would surely forget some things. I would also like it to be an open forum where people can reply with questions/comments.
    I've thought of 3 ways to go about it; I will outline them, give you my feedback about them, and I would appreciate your feedback, even suggestions outside my 3.
    #1. Make a wordpress blog about it. I like this idea the least. It would give me the most freedom of structure and style, but I don't think it would get much exposure at all, and it's too difficult for people to reply; they simply won't reply. If they have a question, they might, but if they have a suggestion, they won't waste their time.
    #2 Create a blog on AAC and post updates. I have only on a couple of occasions looked upon fellow AAC members' blogs. Not that I'm disinterested, but it just never pops up in my face so I don't think about it. Maybe if someone were interested in DIY prosthetics and googled, they might find my blog, but fellow AAC members who might have valuable input would likely never see it.
    #3 Create a thread in general chat and continually post updates to it. This is not ideal, but it's the best idea I've got at the moment. It seems like the best opportunity for omnidirectional communication on the topic, but like most threads, it will likely veer off topic; several times, if kept open and active for 12+ months. It will be a chore for moderation to split it off many times. It will also probably turn into a server space hog, with all the pictures I plan to upload to it; not sure if that's an issue or not. Other issue is that some people might see a 75+ page thread and not even attempt to read through it to find out the current issue/challenge. For that reason, I will likely create other threads for specific issues, and copy or link the information back to the build thread.
    So, what do you suggest?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You could always do the AAC blog and make a thread announcing a new section to garner attention...
    strantor likes this.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    Or a wordpress blog in the same manner. At the bottom of each blog entry, I could post a link back to the AAC thread for comments (if the reader was a member of AAC).
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I, too, think that a combination of threads and blogs would be best.
    Create one blog post that will serve as a Table of Contents. This one could serve as the portal for your project. I believe you can edit your own blog posts.
    Each time you want to start a new "chapter" in your build, create a thread, link it to your blog post and let people comment/discuss on the thread.
    Later on, each time you post a new thread, place a link back to your blog ToC, in case people want to go back and gain some retrospect of the project.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You could start two threads.
    One for the real project that has stash points for future use,
    like in the Components Selection Guide thread by MrChips.
    He also refers to the other thread for comments.
    The other thread can be for the comments.
    Bertus
  6. #12
    Nov 30, 2010
    16,705
    7,358
    The answer is already in front of you. I only wanted to say that I have modified my blogs a couple of times. You click on the pencil symbol. It's that easy.
  7. strantor
    Oct 3, 2010
    4,302
    1,989
  8. tshuck
    Oct 18, 2012
    3,531
    675
  9. nerdegutta
    Dec 15, 2009
    2,572
    807
    Great project.
    We will walk beside you until you reach your goal.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    You will know I'm there by the squeak in my wooden leg.:D
  11. nerdegutta
    Dec 15, 2009
    2,572
    807
    Yup, I know. :) You are the one with the odd walk.:D
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  13. nerdegutta
    Dec 15, 2009
    2,572
    807
    Ha Ha Ha. The silly walk.
