What's that component?
Discussion in 'General Electronics Chat' started by praondevou, Mar 11, 2014.
  1. praondevou
    Thread Starter AAC Fanatic!
    Jul 9, 2011
    2,936
    489
    Hi, I'm trying to find out the current rating of this component.
    Apparently it's in series with a 5V power output in a TV set. (PSU board)
    It looks like a 8 pin TSSOP from Fairchild.
    I would guess a high side switch p-channel MOSFET, but can't seem to find the right one.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    TI OPA552 high voltage op amp?
    Max.
    praondevou likes this.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    No the connections to the pins wouldn't make sense.
  4. inwo
    Nov 7, 2013
    2,435
    315
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The "Q" part number indicates a FET, which makes sense from the pinout.
    Logo seems to be Fairchild?
  6. praondevou
    Jul 9, 2011
    2,936
    489
    Yes I thought so to. But which one ? :)
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Probably a dual MOSFET - isn't that the Fairchild logo on it?
  8. praondevou
    Jul 9, 2011
    2,936
    489
    yes fairchild. looking for the exact type...
  9. odinhg
    Jul 22, 2009
    65
    15
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    No the pinout is simple with ganged pins, it would be a single mosfet.
    If the OP really wants more info we need to see larger picture of the PCB both sides to see how it all connects. :)
  11. odinhg
    Jul 22, 2009
    65
    15
    The one I linked to is a single mosfet. No?
  12. ian field
    Oct 27, 2012
    4,447
    791
    Some are single, some are duals - the duals subdivide into both the same polarity and complementary pairs.
  13. bwilliams60
    Nov 18, 2012
    734
    94
  14. praondevou
    Jul 9, 2011
    2,936
    489
  15. praondevou
    Jul 9, 2011
    2,936
    489
    Makes absolutely sense! That must be the one. Thanks a lot!.
