What's a good oscillator I could buy?
Discussion in 'General Electronics Chat' started by zero_coke, Feb 5, 2013.
  1. zero_coke
    Thread Starter Active Member
    Apr 22, 2009
    294
    I need something to give me an AC sinusoidal signal of frequency between 1 KHz and 20 MHz. Is there such a chip that can do this that I could purchase and be able to vary the frequency?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Maxim had such a chip. But it has been out of production for many years now. Oscillator chips the analog way have kind of died out. Why do you need this :)
  3. zero_coke
    Apr 22, 2009
    294
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The Nightfire oscillator produces ONE frequency. To change the frequency you must change the crystal.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
  6. zero_coke
    Apr 22, 2009
    294
    Thanks guys! I was looking for something way smaller than a function generator because I have access to those. It seems like I will test my circuit with a function generator, and with the correct frequency needed, I'll just swap it with the nightfire oscillator and the appropriate crystal.
    Is this (nightfire oscillator) the only way you can get an analog AC signal at a predetermined frequency without having to buy a bulky function generator? Are there no variable colpitts oscillators out there?
  7. MMcLaren
    Feb 14, 2010
    759
    116
    Have you considered using one of the many AD9850 or AD9851 DDS modules available on ebay?
  8. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    zero_coke likes this.
  9. atferrari
    Jan 6, 2004
    2,666
    784
  10. zero_coke
    Apr 22, 2009
    294
    This seems really interesting. So this thing outputs a sine wave at any frequency between 0 and 60 MHz? Wow that's pretty neat if so. How do you vary the frequency of the signal from 0 to 60 MHz?
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    Direct Digital Synthesis
  12. zero_coke
    Apr 22, 2009
    294
    Yeah pretty interesting. I'm probably going to grab the AD9851 which has buttons and a display so it kinda works like a bench signal generator except without that bulky size and price :)
