What're better? Voltmeters or Voltage Comparators?
Discussion in 'The Projects Forum' started by Raxnos, May 21, 2015.
  1. Raxnos
    May 21, 2015
    18
    Hi People! I'm currently working on a voltage monitoring system to measure quite a few different voltages from different sources and I was wondering, what would be better for monitoring the voltages: voltmeters with an associated program or some voltage comparators? I could possibly have references so the comparators would have comparative voltages relative to the comparator itself.. Any thoughts?
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    a voltmeter gives you the exact measure, comparator justs compares if it's higher or lower.
    ranch vermin likes this.
  3. wayneh
    Sep 9, 2010
    12,389
    3,245
    And all voltage measurements are differential, against some reference point.
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    What output from this monitoring system do you want, Go/No-Go or values?
    How is the output to be monitored?
  5. Raxnos
    May 21, 2015
    18
    I haven't worked out the details yet, but the principal is that the system will monitor the voltages of a range of sources and, when one voltage reaches a certain value (something I'm not completely clear on yet as I have no clue wether or not the value will come from a reference, or from pre-constructed data.) it would send a response signalling that that specific voltage has been met.
  6. Raxnos
    May 21, 2015
    18
    I just realised that I didn't give enough detail.. So... I was basically asking if, from another person's view, a quite a bit more expensive voltmeter setup would be beneficial compared to a much cheaper voltage comparator setup. As both can do the same thing in different ways. There are few upsides I can see to having the voltmeter setup, for example the ability to calibrate it pretty easily and inexpensively. So.. Follow up question, do you know any place , that has a store in the UK, that sells cheap, accurate, small voltmeters with no display? I mean, I need a couple hundred of them, which is why cost is a bit of a drag.. Thanks by the way!
  7. crutschow
    Mar 14, 2008
    13,501
    3,375
    An A/D converter approach would give more flexibility and require less calibration than a comparator based system but would likely require a microcontroller or computer to do the monitoring. Any changes in the voltage limits can then be easily done in software.
    A PC or micro with a USB port could use a USB A/D converter module, such as one of these, to do the voltage monitoring so little on no hardware would need to be built.
    A comparator based approach would require no computer but the voltage limits would likely have to be calibrated, and would need to be manually readjusted if you needed any changes in the limits.
    My choice would be the A/D computer approach.
  8. Raxnos
    May 21, 2015
    18
    Thanks that looks really good! Novice question.. But what do channel and bit mean in this scenario? I know what they generally mean, but I have no clue what they mean here..
  9. blocco a spirale
    Jun 18, 2008
    1,461
    370
    You need "a couple of hundred......cheap, accurate, small voltmeters with no display"?
    Are you serious?
  10. MrChips
    Oct 2, 2009
    12,636
    3,454
    A channel refers to your signal input. Hence an 8-channel data acquisition system (DAQ) will allow you to monitor 8 separate sources.
    A bit is a single binary unit. When the voltage being monitored is converted to numbers it is represented by a quantity of bits.
    The more bits you have, the finer the resolution. Hence if the DAQ converts voltages using 12 bits, you can measure the voltage using a scale of 4096 steps ( 2 multiplied by 2 twelve times). If the DAQ full scale range is 0 to 10V, then the finest step is 10V/4096 = 2.44mV
  11. Raxnos
    May 21, 2015
    18
    Thanks! This makes a LOT more sense now..
  12. crutschow
    Mar 14, 2008
    13,501
    3,375
    How many voltages do you need to monitor at the same time?
    How fast do you need to respond to a change in voltage?
  13. Raxnos
    May 21, 2015
    18
    I'll need to monitor around 200 different voltages. And I have no clue at what frequency the A/Ds can measure up to, so I'll just say that around 1ms (i.e. 1KHz) would quite easily suffice. Thanks!
  14. crutschow
    Mar 14, 2008
    13,501
    3,375
    That's a lot of voltages to monitor.
    Exactly what is this for?
    Do all the voltages have a common ground?
  15. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    An A/D converter takes an Analog signal and converts it to a Digital value that represents the voltage on the input at the time the sample was taken. Your sampling time is what determines the maximum measurable frequency of the signal. You have not described the nature of the signals you are measuring--Are they sinusoidal? DC? Square wave? What is their maximum amplitude? If you're measuring, say, 240VAC, you're going to need to drop the voltage before measuring it, and that would introduce a wide variety of possible errors and inaccuracies.
  16. alfacliff
    Dec 13, 2013
    2,449
    428
    the only place I have seen voltage comparators used is in production, where things are adjusted for a specific level, they are too complicated to set for each voltage.
  17. Raxnos
    May 21, 2015
    18
    It's for an EEG experiment I was working on. Also, what do you mean by common ground? As in they've been grounded by the same thing? If so, then yes they're all grounded by the same thing.
  18. crutschow
    Mar 14, 2008
    13,501
    3,375
    So you also have 200 EEG amplifiers?
    What is you budget for this?
  19. Raxnos
    May 21, 2015
    18
    I was trying to address each problem as it arose. And I don't really have a budget, but at this stage it's more of a proof-of-concept if anything.
  20. kubeek
    Sep 20, 2005
    4,689
    806
    Most of the time it is better to have the whole picture right at the beginning.
    The preamps for the tiny eeg signals will be a lot more complex and expensive than the acquisition part. Sampling say 16 channels at 1 khz is not that big of a deal, but amplifying the signals will be more demanding.
