What you mean by offset
Discussion in 'General Electronics Chat' started by shubham161, Sep 8, 2012.
  1. shubham161
    Jul 22, 2012
    50
    When you hear "offset" (in electronics) what's the first thing that comes to your mind?
  2. Ron H
    Apr 14, 2005
    7,050
    657
    I think of an op amp's input offset voltage. This is the differential input voltage required to get zero volts at the output. In an ideal op amp, the input offset voltage is zero.
    A little English lesson: In your question, change the word "listen" to "hear". When you listen, you may hear sound.
    http://www.learnersdictionary.com/search/listen%5B1%5D
    shubham161 likes this.
  3. shubham161
    Jul 22, 2012
    50
    anybody think of dc shift?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Same thing! Sort of like saying Milk or Cow Juice!
  5. shubham161
    Jul 22, 2012
    50
    hahaha, sorry i wasn't knowing that. thanks!!!
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    In reality, offset can be either good or bad. If you want it, for example to establish a proper operating point such as biasing a transistor for the linear range of input in a simple Class A amplifier, it is good. On the other hand, if you look at the collector of that Class A amplifier, it will have an offset level which is probably not desirable. In most DC type circuits, offset is something that must be recognized and dealt with.
    I would generally look at offset being the DC level upon which an AC signal is imposed.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
