what would you need 880,000 RPM for?
Discussion in 'Power Electronics' started by pjreijiri, Oct 3, 2016.
  1. pjreijiri
    Aug 19, 2015
    60
    hello everyone,
    I was approached recently by someone asking me to build a controller for a motor that has an RPM of 880,000.
    I was wondering why would you need such a high speed. Any small mistake in installation can kill you. I turned him away just because he was being very shady about the project. Also I had a bad feeling about it. First thing that came to mind was building a centrifuge for uranium. I might be wrong, but I did not want to be associated with that project in any way.
    When I told that I won't work on the project unless he shares more information about it, he got really mad and literally said "It is above your pay grade"
    Just out of curiosity, what can you do that would need such a high RPM?
  2. AlbertHall
    Jun 4, 2014
    2,282
    450
    Dental drill?
    ronv likes this.
  3. pjreijiri
    Aug 19, 2015
    60
    does it go that fast?
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    Surgical drills routinely spin this fast.
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Really? 80,000 rpm is the max I've seen advertised in a quick search.
    shortbus likes this.
  6. Kermit2
    Feb 5, 2010
    3,854
    968
    Energy storage via flywheel?
    Would have to be a seriously advanced high tensile strength space-age type material using modern tapered edge design styles.
    Have seen old photographs of the devastation created by over speed destruction of one the early type turbo generators. This thing (if that is what it is) would pack the energy of a large explosive should it come apart. And achieving balance that wouldn't tear it apart would require some especially sensitive measuring equipment.
  7. AlbertHall
    Jun 4, 2014
    2,282
    450
    Wikipedia says (so it must be right) that dental drills go up to 400,000.
  8. pjreijiri
    Aug 19, 2015
    60
    400,000 but not 880,000
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
  10. tcmtech
    Nov 4, 2013
    2,120
    1,754
    Well, If your the idiot who makes Dyson vacuum cleaners, http://www.telegraph.co.uk/technolo...veils-worlds-fastest-motor-in-new-vacuum.html, you would consider 104,000 RPM (brush type RC hobby motors were doing way past that 20 years ago.) to be the world fastest but in reality that's way short of what a simple two pole cylindrical magnet being spun in a HF col can do which is in the million plus RPM range.
    As for practicality of use. I can't see one yet.
  11. pjreijiri
    Aug 19, 2015
    60
    Just for clarification, he wanted to use a BLDC 3 phase motor, and somehow somewhere he asked if the voltage is 1000V
