What would the boolean logic expression be given this condition:
Discussion in 'General Electronics Chat' started by Sebastian Lee, Aug 14, 2016.
  1. Sebastian Lee
    Jul 19, 2016
    Output will be '1' if only two out of three inputs are '1'.
    Moderators note: reduced font and removed bold, as it would be like shouting
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Use three 2-input AND gates to detect each input pair being both 1. Use a 3-input OR gate to see if the output of any of the AND gates is 1. If the three inputs are A, B, C, then the Boolean expression is
    AB + AC + BC, which will be 1 if any pair of inputs is 1
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    But it will also be 1 if all three inputs are 1, which contradicts the stated goal of having the output be 1 if only two out of three inputs are a 1. But this could be just a case of sloppiness on the TS's part, particularly since it would probably be better stated as wanting a 1 only if two of the three inputs are a 1.
    @Sebastian Lee: Did you mean exactly two of three, or at least two of three?
    If the latter, the circuit is called a "majority detector" or sometimes a "voting circuit".
    If you meant the former, then it is almost an even parity detector (which would be a 1 if either exactly zero inputs were 1 or if exactly two inputs are 1. It could be implemented pretty easily starting with either a majority detector or an even parity detector.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,384
    @WBahn
    When it is exact two, it could be an even parity circuit, as it has only 3 bits.
    Bertus
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    So what is the output of an even-parity circuit when all of the inputs are zero?
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,384
    Ai, I see. with all zeros it will also be 1.
    Bertus
  7. knowone
    Aug 24, 2009
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    #7 is the winner.
    ak
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    That's IF the TS meant exactly two of the three. There's no way to be sure unless the TS clarifies what the spec is.
  10. AnalogKid
    Aug 1, 2013
    4,685
    1,297
    I think "exactly" = "only."
    ak
