What would cause the Low state to go to -2 volts vdc? or to +2 volt vdc?
Most Low logic states are close to zero volts, but what faults would cause the logic low state for either TTL or CMOS to go to another voltage other then zero volts?
What are the Common failures that would cause the logic low state to be other then zero volts?
