what will happen if there is no feedback to the power switch IC?
Discussion in 'General Electronics Chat' started by simpsonss, Jan 17, 2010.
  1. simpsonss
    Thread Starter Active Member
    Jul 8, 2008
    In a simple SMPS it contains optoisolator at the secondary part and a power switch IC (m02659R) in a way that the feedback is outputted from the optoisolator to the Feedback Pin of the Power switch IC.
    If let say there is a faulty optoisolator and there is no feedback to the power switch, what will happen to the DRAIN pin of the power switch and will it blow the secondary circuits?
    thank you.
  2. THE_RB
    Feb 11, 2008
    SMPS IC normally oscillate at a maximum duty cycle (typically about 80% duty) and when feedback > threshold the duty cycle is cut. Check any SMPS IC datasheet for the exact feedback regulation system but that is pretty typical.
    So if you lose the feedback the thing will run at full power and the output voltage will rise quite high, and probably blow something.
