Say frequency is double that of the rated frequency. 50 hz to 100hz and 455khz to 1Mhz.A 50 Hz power transformer connected to 60 Hz will just run cooler.
A 60 Hz power transformer connected to 50 Hz is in risk of magnetic saturation and thus overheating.
From your question, we can't tell if you're trying to use a 455KHz transformer at 100 MHz.
Serious lack of information in the question results in serious lack of information in the answer.
double. if we double the frequency how will change it's parameters. I think operating voltage will be high probably power also. if it is then how? what will be the other affects take place?Define "higher".
The eddy current core losses will be higher (double I think).double. if we double the frequency how will change it's parameters. I think operating voltage will be high probably power also. if it is then how? what will be the other affects take place?
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Duane Benson
