What will happen at primary side of transformer
Discussion in 'General Electronics Chat' started by ranatungawk, Sep 6, 2009.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    A I have a 230V/12V, 3A step-down transformer.
    What will happen at primary side of transformer if I attach a 12V/5A device at secondary side? Will primary side attributes (such as voltage or current) change?
  2. Externet
    Nov 29, 2005
    775
    57
    The increased current demand on the secondary will increase the current on the primary and being beyond the 36 VA rated capability of the transformer, it will overheat. It may fail with time running in that condition.
    Miguel
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    The voltage on the secondary will also drop due to the increased voltage drop across the winding. It will overheat the transformer.
  4. marktchaos
    Sep 7, 2009
    5
    Also if the transformer is struggling to provide the extra current it will be operating closer to magnetic saturation and if it goes into saturation really high currents will flow in the primary and it could fail catastrophically. One hopes it was designed with more margin of safety than that though.
