there are 2 transistors both 13005N...which one to check how?more than likely the transistor oscillator has packed up, or on board fuse blown.
One thing that could be missed - they sometimes have a diac relaxation oscillator for startup, a high value resistor charges a small capacitor up to the diac breakover voltage, the discharge current is injected into the lower transistor's base to get it going, there is also usually a clamp diode from the inverter's output node, every time the lower transistor saturates it discharges the diac's capacitor to prevent it firing.Either one of them can become defective, sometimes both. They are connected like push-pull to the transformer. Also check the high voltage capacitors for open or changed value.
Allen
That looks suspiciously like "13005" on the screen print under the transistors - if that's short for MJE13005, they're rated for 400V.Ideally you need to copy the circuit out, and we can see how it works. Is it 12v AC in?
some circuits here to compare
ok...1st picked every components resistors diodes and transistor from board (except transformer,toroid,yellow cap)... checked its value ... resoldered...only 1 resistor showed different value 470k...and replaced fuse wire ...that's all...it worked...Can you say what the fault was?
i replied ...i did it according to everyone suggestions...i forget to reply actual problem since the actual problem may be that 470k and fuse..Such gratitude. We helped him fixed his problem and he wouldn't even say what was the problem and how he fixed it.
i was sure it will be simple fixes..since toroid and transformer will be never (90%) bad ...rest components are cheapless...check and if bad replace...if that 470k is ok then i should go for capacitor replace since i don't know to check caps....all ideas got from aac members.. thanksI'm betting all would have been easy fixes,
Yeah I'm getting slack in my old age.@ RB , You were so close! If only you would have told OP which 470k was bad.
Those yellow band resistors 330k/390k/470k in high voltage circuits like SMPS and inverters are generally used for high voltage feedback, and a good clue is that there are two of them in series (to cover the fact resistors are only good for 200v max, because they have will HV across them in use)....
I for one never suspect resistors first, I'm learning though!
Yeah, metal film are similar spiral construction too.Hello,
When you look at the construction of a carbon film resistor, you can imagine that it is not really capable of handling high voltage:
by Duane Benson
by Aaron Carman
by Robert Keim
by Jake Hertz
