what will be hapened if thiristor is operated at low voltage than rated voltage?
Discussion in 'General Electronics Chat' started by urkirannanda, Oct 17, 2008.
  1. urkirannanda
    Oct 17, 2008
    what will be hapened if thiristor is operated at low voltage than rated voltage? is there any disadvantages?
  2. mik3
    Feb 4, 2008
    4,846
    63
    There will be a problem if you apply a higher voltage than the rated! Thus a lower voltage is fine.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As long as the voltage and current are both lower than the maximum, it will work.
