What Values?
Discussion in 'General Electronics Chat' started by shortbus, Dec 6, 2009.
  1. shortbus
    Thread Starter AAC Fanatic!
    Sep 30, 2009
    4,096
    1,692
    This is probably going to seem like a dumb question to most of you. But I can't seem to find a answer.
    If you have a transformer with the following specs:
    Primary- 240VAC, Secondary- 120VAC, VA- 500. Now what would the values be if the Primary was connected to 120VAC ?
    I know that the Secondary voltage should be 60VAC but what happens to the VA rating?
    Thank you, Cary
  2. dsp_redux
    Apr 11, 2009
    182
    5
    Really depends on what is the load on the secondary. 500VoltsxAmps is the highest you should go.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    You will have ½ of the voltage, and I suspect ½ the current.
  4. shortbus
    Sep 30, 2009
    4,096
    1,692
    Thank you for replying.
    In my first example - 500VA / 120V = 4.16 Amps
    In the second- 250VA / 60V = 4.16Amps
    Is this correct? The available amps stays the same? Even though the VA is halved?
    Or am I thinking wrong that VA is figured the same as Watts?
    Cary
