What type of speaker cable do I need?
Discussion in 'General Electronics Chat' started by Ryan Donahue, May 4, 2014.
  1. Ryan Donahue
    May 4, 2014
    I am restoring an old radio from my grand father. It had been near the beach and there is a lot if corrosion due to salt air. Can anyone identify what type if speaker cable I need. It looks like a single RCA cable but I'm not certain. [​IMG]
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    There's nothing special about it - ordinary zip cord with an RCA plug.
  3. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    It used what is commonly termed - Light lamp cord.
    Max.
  4. Ryan Donahue
    May 4, 2014
    Great, thanks guys. Just want to make sure so I don't mess it up.
  5. Ryan Donahue
    May 4, 2014
  6. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Most of the RCA cords you are going to get are probably single conductor shielded, which would work.
    But if you have the ability, make one up.
    Max.
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    Go to your local hardware store and buy lamp cord or better yet, simply cut off the power cord of any house lamp or electrical appliance, clock or radio that is being thrown away.
  8. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    You'll probably notice that one of the wires has a rib or it's insulation is different. I suspect the rib to be connected to the outer part of the cable, but anything is possible.
    If you can't keep the polarity the same, take a 1.5 V battery and brifly connect it to the speaker and note which way the cone moves. When the battery is connected correctly, the cone will push out. Label the wires the same as the battery terminals, + and -.
    If the cone moved inward, label them in reverse.
    The speakers should be wired the same and would expect the outer conductor of the RCA phono plug to be minus.
    Metalmann and bwilliams60 like this.
  9. #12
    Nov 30, 2010
    16,664
    7,311
    You're running less than half an amp. You need at least 23 AWG wire, and it is impossible to buy a lamp cord too small to carry that much current. Remember, smaller AWG numbers means bigger wire. Us nerds just solder in any old piece of wire we have laying around.
  10. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
  11. #12
    Nov 30, 2010
    16,664
    7,311
    These cords seem to accumulate around here because they are used for TV connections. Video plus 2 channels of sound and I have a box full of them. Go rummage around in your pile of leftover TV connectors.
  12. shortbus
    Sep 30, 2009
    4,088
    1,667
    Many "experts" in the audio world would insist you HAVE to use oxygen free large diameter wire with gold plated connectors if you expect the full range of response from your speaker. :) :D:eek::rolleyes:
  13. ErnieHorning
    Member
    Apr 17, 2014
    67
    17
    An "expert" seems to be anybody that says they are. :rolleyes:
    shortbus likes this.
  14. #12
    Nov 30, 2010
    16,664
    7,311
    You forgot, "finely stranded" to reduce skin effect at 20 KHz. :confused:
    and in this case, I think it's "expert salesman". :D
  15. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Of course, especially with that quality of speaker! . :rolleyes:
    Phasing is not usually required unless more than one speaker is involved.
    Max.
  16. wayneh
    Sep 9, 2010
    12,371
    3,224
    It's worth noting that many pre-made wires with a phono connector on them are intended for line-level signals and are not really meant for higher current as needed in a speaker wire. The current involved here wouldn't be much problem one way or the other, but making your own cable with a piece of zip cord would be better than using a cheap A/V hookup cable. You don't need to worry about the shielding or anything else that would matter in a line-level cable.
  17. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    The premade unshielded one that I pointed out is made for speakers
  18. MrChips
    Oct 2, 2009
    12,623
    3,451
    I simply use lamp cord and make my own solder connection to an RCA plug.
  19. #12
    Nov 30, 2010
    16,664
    7,311
    It was a long time ago, but I made about a dozen of those cables so I would avoid the cheap crimp connection that goes bad in the retail versions. Pushing 40 years, and zero spotty connectors.:p
  20. ErnieHorning
    Member
    Apr 17, 2014
    67
    17
    Even though the RCA connector became common back in the 40’s, it’s still the cheapest connector that you can buy.
    The biggest disadvantage though is that the hot pin makes before the ground.
