What type of motor?...
Discussion in 'General Electronics Chat' started by Nasim2002, Oct 26, 2012.
  1. Nasim2002
    Oct 21, 2012
    11
    What type of motor can I use for my model plane made of thermocol,and it will be of how price and why?:confused: I need experts help. Please help me!
  2. panic mode
    Oct 10, 2011
    1,330
    305
    well how big is the plane? there is difference between 15cm wingspan toy plane and 747
    Nasim2002 likes this.
  3. Nasim2002
    Oct 21, 2012
    11
    I think I will make it's wingspan of almost of 18cm each.
  4. panic mode
    Oct 10, 2011
    1,330
    305
    small DC motor should do the trick. if you need more power (ie. doing acrobatics etc) you can look into brushless DC motors for helicopters. those things are beasts.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    A styrofoam wing that is only 18cm long is tiny.
    I have an RC Parkzone J3 Cub with a total wingspan of 45cm (22.5cm for each wing) and it uses a tiny brushed motor with gears to drive the 10cm long propeller. The brushed motor was also used to open and close a CD tray. The motor wears out its brushes in a few hours of running. I replaced the motor 6 times.
    The airplane with its 3.7V 120mAh Li-Po battery and radio control receiver and servos weighs less than 28 grams. It flys for about 10min or 15 min when there is NO WIND.
    I have two RC E-Flite model airplanes with wingspans of 44cm and 60cm that use very powerful brushless motors that last forever. They are powered from a 200mAh 7.4V Li-Po battery. Wind does not bother them. They weigh about 70 grams and 90 grams.
    I will fly them again now.
  6. Nasim2002
    Oct 21, 2012
    11
    To Panic mode and Adioguru,
    I asked in my first letter that That it will be of how price. Can you answer this??
    After all panic mode, I don't want to use acrobats in my plane.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    My first RC airplane is the Parkzone J-3 Cub. Its tiny replacement brushed motor measures 5mm diameter and is 15mm long. It comes with a brass gear and its wires have a plug.
    It costs $9.99US (535 Indian Rupees).
    The motor holder (with larger gear and propeller shaft) is also available for a low price.
    The tiny 2.4GHz receiver has the motor speed controller, elevator servo and rudder servo on it.
  8. Nasim2002
    Oct 21, 2012
    11
    What will be the weight of the motor?( I am asking this because I know that weight matters in all of it.)
    Can you say?
  9. Audioguru
    Dec 20, 2007
    9,411
    896
  10. Nasim2002
    Oct 21, 2012
    11
    Did you remember that I am making it of my own with thermocol?
    Any guidelines?
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    I think your thermocol is the same as the styrofoam used to make the J-3 Cub model airplane I showed.
    My airplane is made in a factory. I cannot mold the styrofoam like that.
  12. Nasim2002
    Oct 21, 2012
    11
    Can you say where do I Put my battery?
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    The battery on my small RC airplanes is held in the battery space with Velcro (hook and loop). The battery plugs into a jack on a cable of the airplane so it can be unpluged and plugged into the charger.
