What tool to tighten?
Discussion in 'General Electronics Chat' started by ErnieM, May 30, 2014.
  1. ErnieM
    Thread Starter AAC Fanatic!
    Apr 24, 2011
    7,433
    1,623
    What kind of tool fits these knurled nuts used on switches?
    My fingers just don't get them tight. I've resorted to putting the knurled backside and the hex nut on front. At least I can get a wrench on the hex.
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    Slip-joint pliers with serrated teeth that match the knurl pitch.
    Use caution, don't mangle the nut or scratch the faceplate!
    A lockwasher on the rear side, along with a drop of removable Locktite on the threads helps prevent it from coming loose long term, then you don't need to use as much force on the nut.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Surgical hemostats (surgical clamps) are perfect for those nuts. Nice fine serrated jaws. Electronic and industrial supply vendors carry them.
    Ken
    strantor likes this.
  4. mcgyvr
    Oct 15, 2009
    4,783
    973
    "girlie" fingers just don't cut it. :)
    Lets see... whats the name of the tool for a fastener designed to be "tool-less" ??
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    I always thought that one should put the hex nut on first, insert the shaft through the panel, put the serrated nut on to the depth required by the panel thickness, and then tighten the hex nut against the rear of the panel. (Avoids scarring the front of the panel.)
    PackratKing and djsfantasi like this.
  6. sirch2
    Jan 21, 2013
    1,008
    351
    I'd agree with tracecom, set the depth correctly with the knurled nut and then tighten at the back with the hex nut, can be awkward though, a right angle spanner can be handy
  7. gerty
    Aug 30, 2007
    1,154
    304
    + 1 Tracecom, that's the procedure I was taught a hundred years ago....
    Edit: A right angle spanner can be a crows foot wrench..
  8. atferrari
    Jan 6, 2004
    2,662
    782
    Can anyone show a picture of that thing assembled as "it should"?
  9. inwo
    Nov 7, 2013
    2,435
    315
    A wrench from a moped, bicycle, or bi-fold door is thin enough to make a good tool for this.
    Not difficult to make one from scratch with a hacksaw and file.
    atferrari likes this.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I use large pliers with curved concave areas on the jaws that are serrated.
    Good grip, good matching radius, no damage to the round nut.
  11. Markd77
    Sep 7, 2009
    2,803
    594
    You can normally tighten them quite well if you use a sharp, pointy thing and push it round.
  12. GopherT
    Nov 23, 2012
    6,296
    4,018
    I just used these. Work fine but I used a big pair so they are not opened to their extreme when pinching the bolts. The serrations curve at the tip to align with those of the knurled nut.
  13. KJ6EAD
    Apr 30, 2011
    1,426
    363
    absf, ErnieM, #12 and 1 other person like this.
  14. tracecom
    Apr 16, 2010
    3,878
    1,396
    KJ6EAD likes this.
  15. MrChips
    Oct 2, 2009
    12,621
    3,451
    New to me too. Good to know.
    KJ6EAD likes this.
  16. tracecom
    Apr 16, 2010
    3,878
    1,396
    Since there is a tool for tightening those nuts, there should be a standard for defining the number of knurls? per inch/cm. I googled around looking for such, but didn't find it. I did find the attached document and was amused by the switch picture on page 5.
  17. atferrari
    Jan 6, 2004
    2,662
    782
    Quite an old model.
  18. inwo
    Nov 7, 2013
    2,435
    315
    3 hours later.......................................................................................................................................
    Oh I see!!!!!!!!!!!
    djsfantasi likes this.
  19. djsfantasi
    Apr 11, 2010
    2,899
    870
    If you don't have any if these specialized tools, I use a pair of narrow needlenose pliers.
    I'll put a small piece of masking tape on a piece of glass. Then, trace the knurled nut on the tape. With a razor knife, cut out the inside of the circle.
    After inserting the switch and lightly screwing on the nut, I place the masking tape over the nut. Then, using the needlenose pliers doesn't scratch the face plate. Repeat as necessary.
  20. Metalmann
    Dec 8, 2012
    700
    223
    Same here.
