what to do
Discussion in 'General Electronics Chat' started by adanb, Jan 14, 2008.
  1. adanb
    Jan 14, 2008
    i have a 480 panel and i am running some H.I.D lights off of it they are 277 volts there is a yellow wire for the neutral (common) is that ok or does it need to be changed to white
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You need a licensed electrician to do it for you.
    This isn't something for novices to fiddle around with.
    If what you do with that panel causes a fire or other heinous damage, it's highly likely that the insurance company won't pay, because it wasn't done by a licensed electrician. Not to mention, you could get slapped with a huge lawsuit.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Law suit because of? This is different from country to country. This probably happens in United States.
  4. scubasteve_911
    Dec 27, 2007
    1,202
    I have to second Wookie's notion, pay an expert.. Safety superseeds all priorities
    Steve
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Sadly, Americans are indeed lawsuit happy.
    Yellow is an American designation for one of the hot wires. The neutral must be white or gray to satisfy an inspector.
    This work should be performed only by a licensed electrician.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    In regards to lawsuits, yes indeed I'm in the U.S. You can't swing a dead cat here without hitting at least a couple of lawyers - who will then proceed to sue you. :rolleyes:
    In all seriousness though, a 480V service panel is nothing to trifle with. If you happen to make a mistake, you won't get a 2nd chance.
