I have a Gell Lead-Acid battery, 12V 32AH that will only charge to about 11.3V.
Apparently there is a bad cell in it. Can I keeping the battery but in a different capacity? And if so would I recharge it differently?
I was thinking of putting a voltage regulator on it and using it to power a bedside light(2 series strings of white LED's in parallel...tot 20 LED's) and normaly runs off of 3 C Cells. Would this work? Do I need to look out for anything in particular?
