what to do with 4 large capacitors
Discussion in 'General Electronics Chat' started by Joeshmoe, Feb 24, 2007.
  1. Joeshmoe
    Thread Starter Active Member
    Jan 12, 2007
    66
    I have four 8000uf caps at 420V i was wondering was kind of fun things you guys know what to do with them.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You could build an adjustable 0-300V power supply. I'd consider that fun, but that's just me.
  3. kubeek
    Sep 20, 2005
    4,687
    805
    These caps can store cca 2700J. You should always have connected some bleeding resistor to make it safe after power-off.
    Also be careful when manipulating with them, a short circuit could be quite dangerous. Peak RMS power dissipation with four caps in parallel charged to 420V, discharged into 10ohms is cca 5.5kW!
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Coil or rail gun
  5. kubeek
    Sep 20, 2005
    4,687
    805
    BTW is it possible to damage for example a cell phone RF stage by the electromagnetic pulse from the discharge?
    Coil gun: If you manage to transfer just 50% of the energy to the projectile, it will be a seriously deadly weapon. If I remember right a Magnum .500 cartridge has cca 1300J.
  6. Joeshmoe
    Jan 12, 2007
    66
    what kind of bleeding resistor should i use? also i have limited resources so the coilguns that i have built have just been the coil and the cap with a switch in between when i used these capacitors it did not work well
  7. tek_fool
    Feb 24, 2007
    12
  8. kubeek
    Sep 20, 2005
    4,687
    805
    The bleeding resistor is more appropriate in the case of power supply and or when building the whole thing.
    It is a high value resistor which will discharge the caps in some short time like one minute or so. But yesterday I simulated charging the caps by 250mA and it took 50 seconds to get to 400V. The resistor would dissipate in average 50W to discharge it in that time, so it is impossible to use it.
    I think that instead of contactors, you could use an IGBT or mosfet rated for the voltage and current your coil will take.
    Also few days ago there was some other topic in this forum involving a coil gun, with a site which looked quite good.
  9. Joeshmoe
    Jan 12, 2007
    66
    the only problem is that mosfets and igbts that can withstand that the current and voltage im using are expensive
  10. kubeek
    Sep 20, 2005
    4,687
    805
    If the pulses are short enough the transistors could maybe do it.
  11. Joeshmoe
    Jan 12, 2007
    66
    could you show me an example of one that would work? the circuit has low resistance and i don't know the pulse time but i am using a simple self made mechanical switch
  12. andy73
    Member
    Sep 26, 2007
    10
    A mechanical switch is no good, the losses are massive, try IGBT or big scr's nice and simple. you could connect them in para so as to handle the amps flying back and a protective diode bank in anti-para to your coil, so the amps wont get to your caps or switch, but this will increasse your pulse fade-out time, or you could use zener diodes to kill off the pulse quicker!!
    the best you can expect to get from a coilgun is about 1 - 6% energy out, so if you put 2500j in and get 1% out thats 25j out, which can move a 2-3 grame projectile well past the 100m/s barrier, that is if your coil and pulse time are designed correctly, if not then "suckback" gets involved and you may as well just throw your bullet...
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    For bleeding off the voltage when the supply is turned off, consider using four of those 7-watt 115v Christmas tree (or night lite) bulbs wired in series with a NC relay contact; the relay being held open by the charging circuit supply.
    When the supply is turned off, the relay's coil de-energizes closing the contacts and bleeding the power from the caps. Initially, the bulbs will light up when the caps are at full voltage. As the power bleeds off, the voltage across the light bulbs will decrease, allowing the filaments to cool, which decreases their resistance, thereby accellerating the rate of discharge.
    Cheap and effective. The problem will be locating a reasonably-priced relay with the contacts rated at 480v or better.
  14. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Some hobbyists have reached a whopping 4% efficiency in their coilgun experiments. Pretty darn good for hobbyists! (The military is up to what, 10%?)
    Don't discount power MOSFETs - you can get them for a buck a piece if you buy surplus. On rare occasion, one can find good deals on used IGBT bricks as well.
    Here's a Wiki that may help: http://wiki.4hv.org/index.php/Coil_gun
    Of course, PapaBravo's suggestion is a gizmo for years & years of fun... how long will you play with a coilgun?
