What this mean in PIC
Papabravo
Joined Feb 24, 2006
21,225
If those are markings on the package, they are likely to be date codes which specify the year and the week of the year in which the part was produced. Were they causing you any particular anxiety?
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Actually i have 10-12 Pic16f72 with these code.
There are not working as per codes some times free work after re-programming it get work, so i just look on them for knowing it in deep!
Here is the code...
with 6V powers supply, 20Mhz and 22pF Cap at osc.
C:
#include <htc.h>
__CONFIG( BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
#define _XTAL_FREQ 20000000
main(){
TRISB=0x00;
PORTB=0x00;
__delay_ms(400);
    while(1){
        PORTB=0x00;
__delay_ms(400);
        PORTB=0xff;
__delay_ms(400);
ErnieM
Joined Apr 24, 2011
8,377
I once went far looking use dedicated function practice fundamental after reprogramming and full refurbishment.
Papabravo
Joined Feb 24, 2006
21,225
If you bought them from a reputable distributor you can return them for a credit.
I get the joke now -- PIC is a new form of English with syntax and semantics that have to be heard to be understood.
Brownout
Joined Jan 10, 2012
2,390
Here is the code...
When does it stop working? After you remove/apply power?
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
The PIC are fine working in Programmer.
In my circuit there is 4 PIC16f72, in of this 1st and 3rd are working.
the 2nd and 4th is not working at all.
I have checked connection all are fine but i don't understand, what is the hiding problem in it??
I have added 7805 5V supply too.
jpanhalt
Joined Jan 18, 2008
11,087
Ritesh,
Please answer the questions put to you. Otherwise, this will end up another century post thread with no resolution.
What does that mean? Are you doing in-circuit simulation or does it simply mean the chips were erased and programmed successfully according to the programmer? Did you read the chips to see if changes you intended were incorporated?
What happens if you swap 1 with 2 and 3 with 4 in the circuit? Do chips #1 and 3 still work in their new positions?
John
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Does it simply mean the chips were erased and programmed successfully according to the programmer? Did you read the chips to see if changes you intended were incorporated?
Yes, it is working programmer!
chip are working in position 1 an 3 but 2 and 4 are not!!
I test the chip in all position it only work in 1 and 3 only.
jpanhalt
Joined Jan 18, 2008
11,087
The problem is either in your program (i.e., chips in positions 2 and 4 need to function differently than chips in positions 1 and 3) or in the wiring for positions 2 and 4. It is not a problem with your PIC chips.
John
