What the ????
Discussion in 'Off-Topic' started by Kermit2, Nov 23, 2010.
  1. Kermit2
    Thread Starter AAC Fanatic!
    Feb 5, 2010
    3,849
    965
    From my understanding, it is actually a working spot welder, but WOW; I wouldn't have the intestinal fortitude to put power to it. :)
  2. t06afre
    May 11, 2009
    5,939
    1,222
    As long as a transformer is used, it should be OK according to AAC safety rules. So go on just try it:rolleyes::p
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Nah, it needs an LED to meet out standards. John
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Looks like some sturdy "magnet wire" they found.
    It appears the individual laminates aren't insulated from each other, so the output is likely sub-optimal.
  5. Kermit2
    Feb 5, 2010
    3,849
    965
    Ya think? :)
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I remember that thread. I don't think it would pass current muster.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Found pictures of it in action.
    I am guessing Africa for location, some creative things from otherwise junk over there.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope, good old Georgia USA, I think. Wookie would remember him, those pictures are from this site. Reason I mention Wookie is the guy was also a former marine.
    It was about a year ago.
  9. Kermit2
    Feb 5, 2010
    3,849
    965
    Bashing some kit together FO SHO. :)
    Theory has its uses, but application in abysmal conditions is no small proof of mans genius in engineering. :)
    Also, I don't think the surface to surface contact between the steel sheets has the effect of 'shorting' them out electrically to the eddy currents. I'm sure I read papers on studies that showed even the lightest of oxidation layers, on the surfaces, was sufficient to reduce eddy current flow by several orders of magnitude.
    [From my 'rememberings' of eddy current creation in laminated cores]
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  11. R!f@@
    Apr 2, 2009
    8,789
    771
    It's like those company's that has budget cuts.
    Why throw 'em if u can us 'em.
    I remember the guy pointing it tht Maldivians uses them. The nerve of that ....
    He thinks he is better than all of us put together. What I think of him is he is naive then the least experienced member in AAC
    But seriously tht TX could use some industrial bench vices to hold the core
