What standard resistor values to buy? (In bulk)
Discussion in 'General Electronics Chat' started by TheLaw, Jul 11, 2011.
  1. TheLaw
    Sep 2, 2010
    228
    I'm hoping to stock up on some resistors.
    I'm hoping to keep it as simple as possible. Should I just go with multiples of 10? Or should I do 1, 4.7, 10, 47, 100?
    Thanks.
    Edit: This should probably be in resources...
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    It depends on whether you will be doing a lot of analog work or just digital.
    With digital you may get by with just 100, 1K, 10K, 100K and 1M.
    You may need some 10M across XTAL oscillators.
    With analog, the standard 5% set values are commonly used:
    1.0
    1.2
    1.5
    2.2
    2.7
    3.3
    3.9
    4.7
    5.6
    6.8
    7.5
    8.2
    9.1
    If I were starting out I would get these in the following ranges
    x100, x1K, x10k, x100K (assuming that you can buy these as a set or in bulk at discounted prices).
    If not, I would limit the 100K values and up to:
    100K
    220K
    330K
    470K
    1M
    10M
    22M
    Below 100 ohm I would choose:
    10
    47
    The values I use the most are 1K, 10K and 100K.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    PackratKing likes this.
  4. TheLaw
    Sep 2, 2010
    228
    Thank you for all for the information. Yes, I think E6 should be adequate for now. Maybe I'll get E12 in the future. Anything above that...I think I'll just order on demand, if I really need them.
    I guess I'll go with carbon composition, as much as I hate them.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    Something strikes me as wrong about that. Metal film and carbon film seem to be available.
    Mouser
    Carbon film 5.8 cents ea. in quantities of 10
  6. TheLaw
    Sep 2, 2010
    228
    Whooopss. My mistake. I mean't carbon film. Carbon comp is like a 60 year old technology...and they're expensive.
    I'd much rather stock metal films, but I'd have to buy 100s at a time to get close to the price of a carbon film.
  7. #12
    Nov 30, 2010
    16,704
    7,354
    Assuming 5% and 1/2 watt
    Metal oxide, 7 cents each, Mouser
    metal film, 5 cents @ 1/4 watt or 1/2 watt, Mouser
  8. TheLaw
    Sep 2, 2010
    228
    =O
    I think I'll try some metal films then. The 1%s don't even seem to far off in most cases, but carbon films are much cheaper if I buy in bulk...which I'm considering. Is it bad to buy say 100s now, and use them maybe in 10 years?
  9. #12
    Nov 30, 2010
    16,704
    7,354
    Just for stock, I buy 10 of each value.
    When I know I have a project that uses, say, 5 volts and LEDs, I'll buy a bunch of 270's because I like to use 10 ma for my LEDs.
    I tend to use a lot of 270k with vacuum tubes.
    Values less than 1 ohm usually need to be 1 watt or larger.
    I have (8) 2 ohm, 25 watt resistors held in a block with zip-ties so I can make any speaker load I want.
  10. TheLaw
    Sep 2, 2010
    228
    Thank you. I'll try to put all of the suggestions together to make a nice complete kit.
  11. gerty
    Aug 30, 2007
    1,154
    304
    I get mine at Jameco.com, they are $2 per hundred (of the same value) 1/4 watt, never had a problem.
  12. MrChips
    Oct 2, 2009
    12,636
    3,455
    Digi-Key has set of 5 each of 73 values, 5%, 1/4W carbon film,
    part number RS125-ND, $14.95.
    Though the E12 set from Velleman in post#3 appears to be a lot cheaper.
    After that I would buy individual values in bulk - a lot cheaper.
