What Software Use For This Coding?
Muhamad
Joined Mar 31, 2015
14
I want to ask, what software used for this coding? I found it and want to do it for my project.
This coding use At89C51.
This is the coding.
Code:
equ com,0fch  ;defining com and giving initial value 0fcH
equ dat,0fdh  ;defining dat and giving initial value 0fdH
equ eot,0feh  ;defining eot and giving initial value 0feH
equ frqflg,0fh  ;defining frqflg and giving initial value 0fH
org 0000h
mov sp,#30h  ;moving 30H to stack pointer
sjmp over  ;simple jump to over
org 001bh
setb psw.3  ;set bit psw.3,register bank selector 0
inc r0  ;increment r0
cjne r0,#00h  ;checktime
;compare r0 and 00H and jump to checktime if  not equal
inc r1    ;increment r1
cjne r1,#00h  ;checktime
inc r2  ;increment r2
checktime:  ;defining checktime
cjne r2,#11h,goback  ; repeatit 11h times
cjne r1,#27h,goback  ;repet it 27h times
cjne r0,#0c0h,goback  ;repeat it c0h times
clr tr0  ;clear tr0,timer 0 run control bit (OFF)
clr tr1  ;clear tr1,timer 1 run control bit (OFF)
setb frqflg  ;setbit frqflg
goback:  ;defining goback
clr psw.3  ;clear psw.3
reti  ;return interupt
over:
mov p1,#00h
mov dptr,#msg1  ;move msg1 to data pointer
lcall message   ;long call message
mov r0,#00h  ;move 00H to r0
over1:  ;defining over1
mov r1,#00h  ;move 00H to r1
mov r2,#00h  ;move 00H to r2
  mov r3,#00h  ;move 00H to r3
  mov r4,#00h
  mov r5,#00h
  mov r6,#00h
  mov r7,#00h
  mov tcon,#00h  ;move 00H to TCON (clear TCON)
  setb psw.3
mov tmod,#25h  ;timer 0 16 bit counter, timer 1 mode 2 auto reload timer
  mov tl1,#4eh  ;tl1=4eh,the low byte
  mov th1,#0ceh  ;th1=ceh, the high byte
  mov tl0,#00h  ;move 00H to tl1
  mov th0,#00h  ;move 00H to th1
  clr frqflg  ;clear frqflg
  mov tcon,#50h  ;tr1 and tr0 are set to start timer1
   and timer0
mov ie,#88h  ;move 88H to IE, enabling the interrupts
simulate:
  jbc frqflg,getfrq  ;stay until bit is set
  sjmp simulate  ;repeat for reloadin counters
getfrq:
mov ie,#00h  ;move 00H to IE,disabling all interrupts
  mov r1,tl0  ;move value in tl0 to r1
  mov a,r1  ;move value in r1 to accumulator,a
  mov b,#0ah  ;move 0aH to b
div ab  ;div a by 10 and store quotient in a and reminder in b
  mov r4,b  ;move the least significan bit t to r4
div ab  ;divide a by 10, store quotient in a and remainder in b
  mov r3,b  ;move value in b to r3
  mov r2,a  ;move value in a to r2
  lcall display  ;long call display
cjne r1,#80D,l1  ;compare r1 and 80D and jmp to l1 if not equal
l1:  jc l8  ;jump if carry to l8
  lcall send1  ;long call send1
l8:  sub r0,60D  ;defining l8
  jc send1
ljmp over1  ;long jump to over1
display  ;defining display
:mov dptr,#msg0  ;move msg0 to data pointer
  mov a,r2  ;move r2 to accumulator
add a,#30h  ;add 30H to a, ASCII conversion
  lcall ready  ;long call ready
  lcall sendit1  ;long call sendit1
mov a,r3   ;move content in r3 to accumator
add a,#30h  ;adding 30H to accumulator, ASCII conversion
mov a,r4  ;move content of r4 to accumulator
  ret  ;return
message:  ;defining message
acall ready  ;absolute call to ready
  clr a  ;clear accumulator
movc a,@a+dptr  ;move code byte relative to data pointer to accumulator
  inc dptr  ;increment data pointer
cjne a,#eot,comd  ;compare a and eot and jump to comd if not equal
  ret  ;return
comd:  ;defining comd
cjne a,#com,data  ;compare Acc content and com and jump to data if not equal
  clr p0.0  ;compliment p0.0
  sjmp message  ;simple jump to message
data:  ;defining data
cjne a,#dat,sendit  ;compare Acc contents to dat and jump to send it if not equal
  setb p0.0  ;set bit p0.0
  sjmp message  ;simple jump message
sendit:  ;define sendit
mov p2,a  ;move Acc contents to port 2
  clr p0.1    ;clear p0.1
  setb p0.2  ;set bit p0.2
  clr p0.2  ;clear p0.2
ready:  ;defining ready
mov r7,p0  ;move p0 to r7
mov p2,#0ffh  ;move 0ffH to port2 for transmission
clr p0.0  ;clear p0.0,RS=0,select command register
  setb p0.1  ;set bit p0.1, R/W=1 for read
wait:  ;defining wait
  jb p2.7,wait  ;jump to wait if bit in p2.7
  mov p0,r7  ;move content in r7 to p0
  ret  ;return
msg1:  ;defining msg1
.db com,3ch,06h,0eh,01h,81h,dat,"000",com,0c0h,dat,"heart beat",eot
;data heart beat and 000 defined to display at specific location on lcd
msg0:  ;defining msg0
.db com,3ch,06h,0eh,01h,81h,eot
delay2:    ;defining delay2
  setb p1.0  ;set bit p1.0
  mov r6,#01h  ;move 01H to r6
cont2:  ;define cont2
  mov r2,#0ffh  ;move 0ffH to r2
s2:  ;define s2
mov r3,#0ffh  ;move 0ffH to r3
s1:  ;define s1
djnz r3,s1     ;decrement r3 and jump to s1 if r3 is non-zero
djnz r2,s2  ;decrement r2 and jump to s2 if r2 non zero
djnz r6,cont2  ;decrement r6 and jump to cont2 if r6 non zero
  cpl p1.0  ;compliment p1.0
  ret  ;return
sendit1:  ;defining sendit1
mov p2,a     ;move accumulator contents to p2
  clr p0.2  ;clear bit p0.2
  ret    ;return
delay:  ;dfining delay
  mov r6,#50h  ;move 50H to r6
c2:  ;defining c2
  mov r2,#61h  ;move 61H to r2
s20:  ;defining s20
mov r3,#0ffh  ;move offH to r3
s10:    ;defining s10
djnz r3,s10    ;decrement r3 and jump to s10 if r3 non zero
djnz r2,s20     ;decrement r2 and jump to s20 if r2 non zero
djnz r6,c2  ;decrement r6 and jump to c2if r6 non zero
  ret  ;return
send1:    ;defining send1
  mov dptr,#msg2  ;move msg2 to data pointer
  lcall out  ;long call out
  mov dptr,#msg9  ;move msg9 to data pointer
  mov dptr,#msg10  ;move msg10 to data pointer
  mov a,r2  ;move content of r2 to a
  add a,#30h  ;add 30H to accumulator
  lcall out1  ;long call out1
  mov a,r3  ;move content of r3 to Acc
  add a,#30h    ;add 30H to aontent of Acc
  mov a,r4    ;move r4 contents to Acc
  add a,#30h  ;add 30H to Acc contents
  lcall out    ;long call out1
  mov dptr,#msg13  ;move msg13 to data pointer
  mov dptr,#msg14  ;move msg14 to data pointerr
  ret      ;return
out:    ;defining out
lcall delay1  ;long call delay1
trans:  ;defining trans
  mov pcon,#00h    ;move 00H to PCON
  mov tmod,#20h    ;move 20H to TMOD
  mov th1,#0fDh  ;move 0fdH to th1
  setb tr1        ;set bit tr1,T1 run control bit
  mov scon,#40h  ;move 40H to SCON
  clr a    ;clear accmulator
cjne a,#eot,comd1   ;compare accumulator and eot and jump to comd1 if not equal
  ret  ;return
comd1:    ;defining comd1
mov sbuf,a  ;move accumulator contents to SBUF
wait1:    ;defining mait1
jbc ti,fin  ;jump bit carry ti to fin
  ljmp wait1    ;long jmp to wait1
fin:    ;defining fin
ljmp trans    ;long jump to trans
out1:    ;defining out1
  lcall delay1  ;jong call delay1
trans1:  ;defining trans1
  setb tr1  set bit tr1,T1 run control bit
wait2:    ;define wait2
  jbc ti,fin1  ;jump bit carry ti to fin1
  sjmp wait2  ;simple jump wait2
fin1:  ;defining fin1
ret  ;return
delay1:   ;defining delay1
  mov r7,#08h  ;move 08H to r7
d3:  ;defining d3
mov r6,#0ffh  ;move 0ffH to r6
d2:  ;defining d2
mov r5,#0ffh  ;move 0ffH to r5
d1:  ;defining d1
djnz r5,d1  ;decrement r5 and jump to d1 if r5 non zero
djnz r6,d2  ;decrement r6 and jump to d2 if r6 non zero
djnz r7,d  ;decrement r7 and jump to d3 if r7 non zero
  ret  ;returnJ
msg2:  .db "AT+CMGF=1",0dh,eot
msg9:  .db "AT+CMGS=",22h,"9633444713",22h,0dh,22h,”ATA9447700861”,22h,0dh,eot
msg10: .db "heart beat is "
msg13: .db 0dh,eot
msg14: .db 1Ah,eot
Moderators note : please use code tags for pieces of code
atferrari
Joined Jan 6, 2004
4,769
Not an answer to your question but, have you found it like that? Has it any format?
If so, for future postings of code, please use the "code" option from the toolbar.
Just an example of how it could look:
Code:
;DIG_BCD_4:0 are trashed out upon completion.
    MOVF  DIG_BCD_1,W       ;(DIG_BCD_1 + DIG_BCD_3) *2
    ADDWF DIG_BCD_3,W
    MOVWF NROBIN_L
    RLCF NROBIN_L,F
    SWAPF DIG_BCD_2,W       ;+DIG_BCD_2*16 + DIG_BCD_2
    ADDWF DIG_BCD_2,W
    ADDWF NROBIN_L,F
    RLCF DIG_BCD_4,W        ;+(DIG_BCD_4 *2 + DIG_BCD_3) *256
    ADDWF DIG_BCD_3,W
    MOVWF NROBIN_H
    RLCF NROBIN_L,F         ;*2
    RLCF NROBIN_H,F
    SWAPF DIG_BCD_3,W       ;-DIG_BCD_3 *16
    SUBWF NROBIN_L,F
    BTFSS STATUS,C
Easier for everybody, including you.
jpanhalt
Joined Jan 18, 2008
11,087
It is indeed Assembly language, but it is for the AVR/Atmel chips. The instructions are a bit different, so I would suggest looking for a tutorial for that type of MCU.
John
JWHassler
Joined Sep 25, 2013
306
Those are 8051 mnemonics. In fact, the OP stated that.
It looks like the output of a disassembler: all the comments are pointless re-iterations of the menmonics
