What size thickness for single sided PCB?
Discussion in 'General Electronics Chat' started by spinnaker, Feb 15, 2010.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,114
    1,195
    I have a couple of projects pending. One is a power supply 30V at 1 amp. The other a PIC project 5VDC very low current.
    What thickness of copper should I use? Are there other things to consider other than just current? In other words, what is the advantage of a thicker copper. How thin should I go?
  2. retched
    Dec 5, 2009
    5,201
    313
    The thinner copper clad, the wider you will need to draw your higher voltage traces.
    So, as long as you have room on the board, you can use 1oz for a whole lot of projects.
    If you only have room for a small footprint board, you may want to use 2oz board to get larger traces in smaller areas.
    Someone probably has a chart or equation on trace size.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    1 oz copper, and 1/16" thick is standard for most PCBs, unless very low power and small then I go with the 1/32" thick.
  4. spinnaker
    Oct 29, 2009
    5,114
    1,195
    Thanks once again everyone.
    So this would be good for most projects? He does not have the weight. Does that equate into the other numbers somehow?
    I guess maybe I should ask, what is meant by 1 oz?
  5. retched
    Dec 5, 2009
    5,201
    313
    the Ounce size is the amount of copper per square foot of board. so 1oz perSqFt
  6. spinnaker
    Oct 29, 2009
    5,114
    1,195
    So the link I posted, anyway to tell if it is 1oz?
  7. retched
    Dec 5, 2009
    5,201
    313
    no.. no way to tell from the ad. Send him an email, and let us know.
  8. spinnaker
    Oct 29, 2009
    5,114
    1,195
    Thanks. Just sent hum another email Seems like a pretty good price if it is quality material.
    How do I know it is is really 1 oz (if that is what he says it is)? I mean after I buy it.
  9. retched
    Dec 5, 2009
    5,201
    313
    There are some etching tests you can do. I don't remember the exact times and temperatures. But I think it was along the lines of .... 1cm square of board in 25deg Celsius ferric chloride should dissolve half oz in 2min, 1oz in 4min and 2oz in 8 min.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I wouldn't overthink this one too much. It is possible you may make a mistake, but the odds are it won't matter.
    If you have a trace that is too high resistance you can lay thin wire over it (soldered as part of the trace).
    The only application I've found where it really matters is things like RF traces, where you are trying to make a transmission line in the PCB. I've made some dandy oscillators that were meant to be amplifiers because of it.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
  12. spinnaker
    Oct 29, 2009
    5,114
    1,195
    Yeah, he gets a 100% rating so I guess if he says it is 1oz it is 1oz. But he did not say how to tell because it is not in the ad. :)
