What Size resistor to use?
Discussion in 'The Projects Forum' started by Derek Emerson, Mar 16, 2016.
  1. Derek Emerson
    Mar 16, 2016
    Hi All
    I'm sure this will be an amazingly simple question for someone to answer, however as a hobbyist in electronics I am looking for some clarification.
    I have a 2 pin bi-colour LED (Red/Green) and will be running it from a PP3 battery (9v). I simply want to be able to put the led on the battery one way for one colour and the other way round for the other colour. My question is this "What size resistor sahould I use, the LED I will be using is this one:
    http://uk.rs-online.com/web/p/visible-leds/2285720/
    Kind Regards
    Nelix
  2. GopherT
    Nov 23, 2012
    6,303
    4,021
    To calculate this, you need battery voltage = 9V
    Forward voltage drop of diode = 2V
    Current max of LED = 25mA (so we will use 10 mA or so)
    (9V - 2V) / 0.010A = 7V / 0.010A = 700 ohms.
    If you want 20 mA, you can calculate that easily now. Or for 5mA
    Anything in the range of 390 to 1500 should be ok (adjust to your desired battery life and brightness).
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    Just to add a bit..
    resistance calculation is
    (Vb-Vf)/I = R
    Where
    Vb=supply voltage
    Vf=LED forward voltage rating
    I = desired LED current in amps
    R= calculated resistance
    So
    (9-2)/.010 = 700 ohms (using Gophers Vf and I numbers above)
    Then you also need to calculate for the min wattage of the resistor needed.
    So now..
    P=2*((Vb-Vf)*I)
    Where
    P = calculated minimum resistor wattage rating..
    So
    2*(7*.010) = .14 watts minimum (I'd use a 1/4W resistor.. or .25W vs a 1/8W that will run HOT)
    Note: the 2* is a "safety factor".. You always want to double or triple the calculated wattage to avoid the resistor running too hot..
    And with wattage its always "minimum" having a higher wattage resistor is totally fine.. It won't effect LED current or anything.. Just takes up more space and run cooler the higher you go..
    To learn something more and allow you to remember these easier.. Check out this..
    http://www.ohmslawcalculator.com/ohms-law-wheel
    Notice our calculations are based on those proven formulas.. (just adjusted some for wattage safety factor and the fact that an LED essentially "eats" some of the voltage dictated on its forward voltage rating..)
    P=E*I = wattage calculation
    R=E/I = resistance calculation
    GopherT likes this.
  4. Derek Emerson
    Mar 16, 2016
    Thanks for the help.
    I had worked it out at around 340 but as mentioned I just wanted some clarification.
    Thanks again, it is very much appreciated, you have all been most helpful.
    I'll take a look at the link and save it for future reference.
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    It could be 340 depending on the Vf of the LED.. Or multiple LEDs in series
