what single phase ac motor is this
Discussion in 'The Projects Forum' started by campeck, Oct 27, 2012.
  1. campeck
    Thread Starter Active Member
    Sep 5, 2009
    194
    it has on cap in parallel with the main. and seems to only run when hooking up main across the cap. most ac motors have two caps or one in series with one winding.
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    It is a single-phase induction motor. The wiring diagram on the right would likely show how the motor is connected, but that is hidden in the picture.
  3. campeck
    Sep 5, 2009
    194
    It is slightly confusing...
  4. gerty
    Aug 30, 2007
    1,154
    304
    "Line" indicates the incoming power. Connect as shown for one direction, put tape on unused wire. Connect capacitor as shown (orange and yellow). To change direction, disconnect black and connect line to red.
  5. campeck
    Sep 5, 2009
    194
    ok. I will try that when I get home.
    I don't quite understand the internal connections to this motor.
