I work in IT, mainly in computer repair and HDD data recovery.
The ways of data recovery are filled with myths, do's and dont's, and the people who master it, won't ever give you a single hint telling if you are in the correct path.
Every day now, we are receiving USB flash drives that need pcb / chip replacement, and I would like to ask you, what tools (is a hot air station doable ? do i need a pre heating plate ?) should be used for the transplant of the little chip you see in the image ? I understand some components might be sensitive to more or less heat then anothers.
Any of you ever worked in this kind of thing ?
Thank you so much for spending your time reading this.
Miguel
Miguel
