what sensor is used in this video
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Sep 1, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Below is link for video, which sensor is used here which can detect the glove/ball/hand touch?
  2. Dodgydave
    Jun 22, 2012
    5,156
    772
    Photo cell, ultrasonic, light led opto, piezo,,,,,,,
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Will resistive touch work. Although person also hit it with glove.
    SO I dont know it may break? Is there any way it can be made strong enough??
  4. hp1729
    Nov 23, 2015
    2,105
    235
    Re: photocell and LED in row and column? How do you deal with two hits on the same column at the same time?
    Maybe pressure sensitive resistors.
    Maybe force sensing resistors
    http://www.jameco.com/z/1645-Pololu...re-1Oz-22Lbs-2-Leads-0-1-Spacing_2136471.html
  5. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I have tried using resisitive touch. But not much success. There is voltage change across x & y axis. But it need pressire to do that. A simple hand touch is not successful.
    Will try to use piezo & check
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. DickCappels
    Aug 21, 2008
    2,777
    674
    Tact switched, or any one of thousands of elrctro-mechanical switches
  8. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    But where to place this electro-mech switch? What would be right position??
  9. DickCappels
    Aug 21, 2008
    2,777
    674
    It may not be critical at all.
