What replacement diode should I use?
Discussion in 'General Electronics Chat' started by AKnogood, Nov 21, 2013.
  1. AKnogood
    Nov 21, 2013
    17
    My father-in-law has an old soldering unit in his garage and he blew 2 diodes on the electronic board. I'm trying to find some replacement parts.
    Here you can see a photo I took of the board.
    I know the part number for the diode "A" is 1N4004 but I can't find the part number for the bigger diode "B". And there's no other diode of the same size on the board.
    Any idea what diode I could use as a replacement for diode "B"? If you need any more info please let me know!
  2. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    can you take a photo of the track side, and a full picture of the component side so we can trace the circuit.
    It may just be an ordinary silicon diode or a Zener, have you tried to look underneath the diode for markings?
  4. AKnogood
    Nov 21, 2013
    17
  5. t06afre
    May 11, 2009
    5,939
    1,222
    For diode B it might very well be a zener diode, but no idea which it is. I suspect diode B might also have burned the cap besides it. Have you done some work with Google using the product number/ID for the solder station. I also suggest while you are at it fixing the unit. Replace all the electrolyte caps. As they have probably reached their life span, and dried out.
  6. AKnogood
    Nov 21, 2013
    17
    Good to know about the electrolytics capacitors, Ill take a look at that. Thanks!
