What Pot to use for LED Dimmer?
222fbj
Joined Apr 27, 2009
I built a few LED lights using various types of LEDs. I would like to add a pot (on/off and dimmer). How do I go about determining what pot(s) are appropriate?
I have done some price/shopping for pots and they range from $2 to 'too much$$$'. Hopefully there is an inexpensive Pot that will work for me.
thanks
Wendy
Joined Mar 24, 2008
23,421
What is your power supply? You can use almost anything, but you have to match it to what you have.
Have you read this?
LEDs, 555s, Flashers, and Light Chasers
Pay special attention to the first chapter, and figures 1 and 2, to understand LEDs. You will need a minumum resistor, say 100Ω (but it depends on the power supply) to set the maximum current. A 5KΩ pot will adjust it down from there, even a 1KΩ might work, and a 10KΩ will have a lot of dead range.
ruleworld
Joined Jun 9, 2006
22
if u have a high source like 12v then always use a series resistor(about 1Kohm) else the LED will burn when u turn the pot value too low.
Bernard
Joined Aug 7, 2008
5,784
Pots with switches are not as plentyfull as without, and most do not give wattage. Try for 1/4 W or higher. ' found an example: All Electronics Cat # LTPS-20k $ .75 US 20kΩ, with switch +postage. 5k-10k would be my choice. For full-range control connect pot across power supply, cathode of LED to neg, anode to 510Ω , other end to wiper.[ assuming a 20 mA LED].
SgtWookie
Joined Jul 17, 2007
22,230
The one item that's missing from Bill Marsden's link would perhaps be the most useful in your case.
That's a 555 timer PWM circuit. A 100k pot is quite useful for such circuits.
