What parts needed when building multiple Arduino projects?
Discussion in 'Embedded Systems and Microcontrollers' started by Merlysys, Dec 8, 2013.
  1. Merlysys
    Nov 17, 2013
    23
    I am building 3 devices and each of them needs an Arduino as its brains. I am about to order parts so pls tell me if the following strategy is the right one?
    I am doing the development on board A (see pic below), its the usual arduino uno board with USB interface to download programs from PC
    http://www.ebay.ca/itm/171167497907
    B- I will order 3 of these boards as there are 3 products to build
    http://www.ebay.ca/itm/200957063666
    C- To download the program to each board B from the PC I will order 1 board C
    http://www.ebay.ca/itm/141092401021
    Once the program is downloaded and it works I will remove the board C
    Is that the way to go or am I missing something here?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    It is some applications. That allow the Arduino unit it self to be AVR controller programmer. This page may give you some ideas http://electronics.stackexchange.co...use-an-arduino-uno-as-an-atmega328-programmer
    The point is to first download the Arduino bootloader into a blank chip. Then program it with whatever you have made with the Arduino system. After that the controller should work OK with only correct power and a correctly connected 16 MHz crystal. I am not Arduino user my self. So I might be wrong here
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I've had mixed success with USB to serial converters. Personally, I'd use an older computer with a serial port and forget the converter. It may however work fine, let us know.
  4. MrSoftware
    Oct 29, 2013
    545
    133
  5. sirch2
    Jan 21, 2013
    1,008
    351
    What you propose looks fine to me, I've had no problems with FTDI/serial converters.
