What part is this?
Discussion in 'General Electronics Chat' started by daniel123, Mar 29, 2013.
  1. daniel123
    Mar 29, 2013
    This tuner knob is from a 20 year old piece of lab equipment, and is apparently not working. I don't even know if it is a variable resistor or capacitor. Can someone give me an idea of what it might be (and even better, how to find a replacement?)
  2. panic mode
    Oct 10, 2011
    1,328
    305
    if i see correctly, there is a coil in there. this is a variable inductor
  3. sfeinsmith
    Mar 20, 2013
    16
    It seems difficult to view one side but it looks like tunable variable choke. If you can see ferrite slug inside the tube, if yes, it is a variable choke. I can see one wire broke loose. You need to check with LCR or ohmmeter to see if this choke winding is good. If not, then you can loose the winding by count how many turns then measure AWG wiring then you can rewind it. You can view youtube and get an idea to build a winding machine to create new one. Good luck
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I agree. Obviously, one of the connecting wires has broken off.
  5. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    It is a multi layer litze coil with a tuning screw.
    Bertus
  6. Neosec
    Member
    Feb 25, 2013
    36
    Yup tuning choke. Coil is the red ring around the outside, the tuning slug is inside the tube and adjusted up and down by the screw at the top.
  7. #12
    Nov 30, 2010
    16,704
    7,352
    Take it apart and wind a new one yourself?:eek:
    I don't think so.
    Ron H likes this.
