I'm working on the circuits in this article: http://grad.uprm.edu/tesis/naranjobueno.pdf
The filter circuit is on pg. 80 of 156
I used 1/(2pi*RC) to figure out the component values for the filter circuit. I ran a simulation on LTSpice with the components and the LF356 sub and the results were good. Then I built the circuit using the values and its not giving the same results.
some information on the wanted functions:
Low Pass Cutoff = 200KHz
High Pass Cutoff = 4kHz
Here is what I'm actually getting:
1st stage
High Pass cutoff= 30kHz R=6.8k C= 5.6n
2nd stage
High Pass cutoff= 30kHz R=18k C=2.2n
3rd stage
95% of voltage is lost across input resistor
R=8.2k C=100n
I'm using ceramic capacitors and carbon film resistors. The capacitors I've had for a long time and could be bad or something but the resistors are fairly new.
Please can anybody tell me what I did wrong? Any suggestions or comments would be very helpful.
Thanks.
1st stage
2nd stage
3rd stage
R=8.2k C=100n
Thanks.
