This is in relation to my other thread, BUT it's different due to being a stand alone unit.
These chips can regulate down to 1.1v and up to 4.5v and apparently can supply over 35A. So it's exactly what I need, and it's used for CPUs so that's even better. Now the evaluation kit comes preset at 2.5v@8A, which is close to the 2.9v I need it to do, but a far cry from the 35A I'd need.
Anyways, here's the documentation on the assembled regulator
http://datasheets.maxim-ic.com/en/ds/MAX1639EVKIT.pdf
Doc on the chip itself
http://datasheets.maxim-ic.com/en/ds/MAX1639.pdf
Older versions if anyone thinks it'd be better to use for which ever reason
Kit(1625 is the non-programmable version, 1624 is programmable, which ever would be best):
http://datasheets.maxim-ic.com/en/ds/MAX1625EVKIT.pdf (Non, 2.5@5A)
http://datasheets.maxim-ic.com/en/ds/MAX1624EVKIT.pdf (Prgm, 1.1-3.5@11.5A)
Chip
http://datasheets.maxim-ic.com/en/ds/MAX1624-MAX1625.pdf
1638 (programmable)
Kit (1.3-3.5v@14A)
http://datasheets.maxim-ic.com/en/ds/MAX1638EVKIT.pdf
Chip
http://datasheets.maxim-ic.com/en/ds/MAX1638.pdf
I hope this isn't too big of a task :\ I don't understand the fine details of this sort of thing, so I can't really grasp the complexity of doing something as what I'm asking.
Thanks!
Chip
1638 (programmable)
Kit (1.3-3.5v@14A)
Chip
Thanks!
