What MOSFETs should I stock?
Discussion in 'General Electronics Chat' started by TheLaw, Aug 9, 2011.
  1. TheLaw
    Sep 2, 2010
    228
    I have a lot of BJTs stocked up, but I realized I have few MOSFETs, and I'd really like to start tinkering with MOSFETS, because I really haven't done much with them.
    So for small signal MOSFETs, I think I'll buy 2n7000. Is that good?
    I'd also like to buy a few power MOSFETs. Is there any that come to mind? On Mouser, I found the FQP7P06, which came in at $0.52 if I buy 25...not terrible, I don't think. Some of the other power mosfets are upwards of $1.50 each for 25.
    Thanks.
  2. gerty
    Aug 30, 2007
    1,154
    304
    If you are going to be controlling some of these with micro controllers you might look into getting some logic level mosfets, they can be turned on with 5v. When it comes to building up an inventory, what you need depends on what you plan on doing..
  3. iONic
    Nov 16, 2007
    1,422
    68
    Stock the one you will use, of course! It depends on your applications. I find that when I buy parts for one application, lets say, resistors I often only need 1 but I but a bucks worth. I do the same with other components, making sure I have enough for the project, a spare in case I botch something, then maybe enough to duplicate the project.
    You inventory will build up and reflect your interests.
  4. #12
    Nov 30, 2010
    16,663
    7,307
    I was poking around today looking for p-channel mosfets and found a few at Digikey.
  5. TheLaw
    Sep 2, 2010
    228
    Thanks. Well the reason I ask is because I never really use MOSFETs and I want to start experimenting a little bit. So I'm just looking for any suggestions on what might be some good cheap parts to start with.
    Thanks #12. I'll look at those.
    And I see what you mean by the 5V fets. Might be helpful. I don't do too much MCU stuff, but hey, there's always a time to start.
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    I used the IRF3205 a few times because it has low on resistance and, for a 1 A application, didn't need a heat sink (I used it with a 9 V battery for the gate voltage).
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The IRLD014PBF and IRLD024PBF are handy little 60v 1.4a & 2.4a (respectively) 1.3 Watt logic level N-ch MOSFETs that are great for using on breadboards, as they come in a 4-pin DIP package. They won't ream out your breadboard's sockets like large TO-220's will. They don't have a lot of current sinking ability, but you can't sink much current using a breadboard anyway or you'll melt it.
