What mosfet to use
Discussion in 'General Electronics Chat' started by electronucks, Jun 20, 2012.
  1. electronucks
    Jun 16, 2012
    14
    I have a TI UCC383-adj chip and need to use the inhibit pin however the inhibit pin is for a N/C switch. I need to use a small tact switch so i must convert it to a N/O . I know i will need to use a mosfet but what kind? Does anyone have a mosfet part number that will work for this
    Btw the chip will be ran off a 7.4v li-po . Heres the datasheet for the chip
    http://www.ti.com/lit/ds/symlink/ucc383-adj.pdf
    Things i need
    -Small package recomended
    - cheapest mosfet possible
    -How to use it in the circuit
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    Fdv301
    tsm2303
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    2N7000
    (plus some more dummy characters so the post gets accepted)
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    Are you talking about the SD/CT pin that you pull low to enable shutdown?
    Maybe you mean you have a momentary switch or something?
    Did you read page 8?
  5. electronucks
    Jun 16, 2012
    14
    No, nothing to do with shutdown . I need it so i can use a low amp tact(mometary) switch.Thats why i need to use the inhibit/on/off pin however they dont make tact switches in N/C configuration which is why i need to change that to be able to use a N/O switch.I guess using a mosfet of vin will work too.
    Basically anyway possible that i can use a N/O tact switch to turn the thing on and not need a 5A pushbutton or N/C switch.
  6. Bernard
    Aug 7, 2008
    4,232
    414
    Just about any N ch FET, BS170 [R. S.], 2N7000?, NTE490, etc.
  7. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Of course, you could always use a pull up resistor on the inhibit pin and a common NO switch to ground and skip the FET altogether.
