What materials do i need to start my first circuit board project?
Discussion in 'Homework Help' started by DJG2011, Jul 23, 2011.
  1. DJG2011
    Jul 23, 2011
    i want to start my first project, i have all the tools but what materials do i need, all i want to make is a simple circuit board with a LED on it that lights up when i press a button, so what is everythink i need meaning what type of circuit board and and LED lights ect. ect. because im a complete noob ;) so EVERYTHNK i need to do it
    thanks -josh
  2. maia31
    Jul 20, 2011
    6
    well
    first of all is wire:)
    then breadboard
    third is voltmeter or ohm meter
    and diode
    and if you don't have any dc power maby a battery
    sorry for may bad eng
  3. debjit625
    Apr 17, 2010
    790
    186
    1)LED (Red one)
    2)470 ohms resistor
    3)9V battery
    4)Push switch.
    If you want to do it in breadboard(a board where you can insert your component with soldering)
    1)Breadboard
    2)Some wires suitable for your breadboard
    If you want to do it in Veroboard.
    1)Veroboard
    2)25 to 30 watt soldering iron
    3)solder (use 60/40 rosin core)
    I dont think you want to make a PCB for this circuit...
    Good Luck
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends on what you mean start a circuit board. Here is an article I haven't finished yet.
    Prototyping Electronic Circuits
    If you ever want to make something really fancy (warning, this is the advanced method)...
    How I make PCBs
    The AAC book has a Volume devoted to this, see the link on top (Volume VI). It will cover tools and materials, techniques and projects. It is worth a read.
