What materials are wall plugs made of apart from brass?
Discussion in 'General Electronics Chat' started by Rolland B. Heiss, Mar 29, 2015.
  1. Rolland B. Heiss
    Feb 4, 2015
    236
    40
    I've got what may be a basic question but I need to know more because I have a few power cords I've removed from non working units and some of the AC plugs (the parts that make contact with the wall outlet) look silver as opposed to the yellowish color of brass. Magnets do not stick to them so they are obviously non ferrous but what are the metals used if not brass? Aluminum perhaps? I'm trying to separate metals into containers so I know exactly what they are and when a project comes along requiring a certain metal I'll know which container to draw from for any given project. Any input would be greatly appreciated!
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Most likely nickel
    Rolland B. Heiss likes this.
  3. BReeves
    Member
    Nov 24, 2012
    412
    64
    Most likely nickel plated brass.
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    In addition to the above cited Monels (Cu, Ni), Brasses (Cu, Zn) and Bronzes (Cu, Sn) --- Alloys comprised of two or more of Zn, Ag, Sb and Mo are occasionally encountered in contact conductors ---- But definitely not aluminum! -- Although Al is yet in wide use as an electrical conductor, its ineradicable insulating oxide and flammability preclude 'active contact' applications...
    As a side note: Inasmuch as Al is a relatively reactive element (à la calcium), aluminum alloys preclusive or disruptive of oxide formation are prey of rapid (atmospheric) corrosion (the amalgam, for instance, is notorious in this regard)... Moreover, while aluminum is occasionally plated with copper or other metals (as, for instance, to enhance 'solderability' ), such is not cost effective for non-specialized applications...
    Best regards
    HP
  5. Rolland B. Heiss
    Feb 4, 2015
    236
    40
    This is very likely if the nickel plate is too thin for a magnet to stick to it. Magnets do not stick to these silver colored plugs.
  6. Rolland B. Heiss
    Feb 4, 2015
    236
    40
    Thanks for the response HP. I appreciate the time you took to do so in such a descriptive and informative fashion.
  7. tjohnson
    Dec 23, 2014
    618
    122
  8. Rolland B. Heiss
    Feb 4, 2015
    236
    40
  9. takao21203
    Apr 28, 2012
    3,578
    463
    I was thinking it could be CrNi perhaps?
    UK plugs are often plain brass altough there are also silvery ones.
    EU plugs are always coated but the core is brass I think.
    The US plugs are just thin blades not sure if they have a core.
    You dont normally seperate such waste but give it to electrical recycler (aka ewaste).
    And nobody cares a coating on a few plugs (for recycling), you dont need to sepersate or test that.
