What material are diode pins made from?
YoctoByte
Joined Oct 27, 2015
Today I noticed that normal diodes are not attracted by magnets. Almost all other components I have tested have iron pins (or nickel or something); LEDs, resistors, transistors, capacitors, except for diodes.
I also noticed that the pins of several types of rectifiers (containing diodes) are also not made of iron. Zener diodes on the other hand do have iron pins.
What is the reason the pins of diodes do not contain any magnetic material? And what material is it made from?
alfacliff
Joined Dec 13, 2013
2,458
rectifyers are designed to carry current, iron has a fairly high resistance., I have even seen some diodes with silver leads, silver conducts very well and solders well too. a lot are tinned copper.
MaxHeadRoom
Joined Jul 18, 2013
28,688
Usually tin plated copper, the gauge is usually slightly higher than comparable sized components due to the leads acting as heat sinks.
Max.
dl324
Joined Mar 30, 2015
16,922
They started using silver when gold got expensive. I have some from the late 70's that I kept in semi-sealed containers and the silver has only tarnished slightly.
ian field
Joined Oct 27, 2012
6,536
When I started out, a lot of IC manufacturers gold plated the pins.
That fell out of favour because the gold migrated through the solder, I vaguely remember reading something about a microns-thick oxide layer under the gold plating. It was OK while the gold remained, but caused reliability issues years down the line.
Although; AFAIK: gold plating is still very common on RF power devices.
Solid gold pins would have been prohibitively expensive - and probably would've dissolved into the melted solder during assembly.
recklessrog
Joined May 23, 2013
985
I can't remember why, but Rhodium was plated onto gold onto copper on some components used in the analogue engine control computers that went into the cold war secret development jets a company I worked for were designing.
It may have been because of the elevated ppO2 that was in the pressurised environment.
recklessrog
Joined May 23, 2013
985
On second thoughts, maybe it was the printed circuit boards that were Rhodium plated, may have been both though. It was a long time ago and my memory is not so clear.
RichardO
Joined May 4, 2013
2,270
I once worked on a project where the customer wanted Rhodium plating on edge connector fingers of a "paddle board". They thought the Rhodium would last longer than gold for repeated plugging and unplugging.
After finding out that Rhodium plating was not a common process for PCB's, the decided that it was not that important. The price of stocking a plating tank was going to be $25,000 just to get started. This may have been a factor in their decision. ;)
recklessrog
Joined May 23, 2013
985
That's very probably the reason why it was almost a capital punishment crime if a circuit board was damaged!!! Although of course, I don't think cost was a prime consideration in our case. I know the solder used had a very special composition, and if any was required for re-working, we were issued with a very small roll that was weighed before and after use and all work was meticulously logged.
mcgyvr
Joined Oct 15, 2009
5,394
Mainly silver, also using hydrogen sulphide.
Don't confuse the lead finish with lead material..
Diode/resistor,etc.. "pins (leads)" are made from copper/copper alloys/dumet and are typically finished (plated) with tin, silver, or tin/lead plating..
ROHS requirements have done away with lead now in lead plating.
Bernard
Joined Aug 7, 2008
5,784
From memory, when 1N4xxx series first came out Mfg. claimed pure silver leads & the 1N4007's that I was using seemed to be so, 1972 ?, but in checking stock, 65 ea. 1n4XXX, all 1N4048's -iron, 1N4XXx, one silver, one iron, remainder Cu plated
recklessrog
Joined May 23, 2013
985
Isn't the English language great! "I was LED by a LEAD, my feet felt as heavy as LEAD!
Just to be really silly, say this out loud three times__One smart fellow, he felt smart!
Why is "abbreviation" such a long word!!!
