What makes an AAC user an "Active Member"?
Discussion in 'Off-Topic' started by tjohnson, Jun 1, 2015.
  1. tjohnson
    Thread Starter Active Member
    Dec 23, 2014
    618
    122
    I haven't been able to figure out what makes an AAC user an "Active Member." DumboFixer, who has made 219 posts over the past 6 years, is listed as an Active Member. pwdixon has made 319 posts over the past 2.5 years, so he has a greater post frequency than DumboFixer, yet he is only listed as a Member. Since I have made 291 posts over a period of 0.5 years, I have a greater post frequency then both DumboFixer and pwdixon, yet I am not listed as an Active Member either. How does an AAC user attain this status?
    (No offense intended to any members mentioned in this post; I'm merely using them as examples.)
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    I guess the Mods knows.
  3. joeyd999
    Jun 6, 2011
    2,756
    2,916
    I run.
    Brownout likes this.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I believe they are simply levels to show how many posts you have on the forums (excluding Off-Topic).
    Then there are special groups that are only done by the moderating team/admins.
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    This is a very good question. I always assumed it had to do with the post count, but perhaps that's not the case....?
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That's a thought. Off-topic posts are not counted as "Messages", but if the site still counts them it may use it to determine the user status. I wonder if 500+ posts (total, including OT) gets you the "Active Member" status?
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Scratch that, pwdixon has 322 posts total.
  8. tshuck
    Oct 18, 2012
    3,531
    675
    I'm sure @bertus can tell us...
  9. killivolt
    Jan 10, 2010
    432
    351
    The only real difference I see is the Number of friends. Likes and Trophy points are around the same.
    kv?
  10. JoeJester
    Apr 26, 2005
    3,392
    1,211
    Most forums use a post count to discriminate between the categories of membership.
    It is up to the forum owner to develop their own metrics if they are delving into the a deeper analysis of their members.
    This forum, like a lot of Q&A type forums, will have a core group that remains and the vast majority of the users leave once their question has been answered. A couple of years ago, I looked at two forums to get an idea of membership retention. It lead me to internet culture and a host of other metrics. Anyways, in three months time, there were 3008 members visiting AAC. Below is a graph of their membership time. It illustrated the transient nature of the membership, from one post and done to the long term membership.
    DerStrom8 likes this.
  11. Sonoran Desert Tortoise
    Member
    Oct 30, 2014
    53
    34
    The mods determine your status based on the amount of humor or irony in your signature line. Those with a status of "Beloved Member" have a great signature line.
  12. WBahn
    Mar 31, 2012
    18,079
    4,917
    As a mod, I can tell you that I have absolutely no idea.
    There is a baseline based on post count (and I believe it excludes OT forum posts), but there are other categories that appear to be manually assigned (by the admins, I presume).
    It was easier to explore this with the old VB software because you could navigate the entire membership listing instead of just the top twenty (or specific members).
    There are also identifiable errors in either the forum software or the AAC configurations. The most glaring one is in the Trophy Points calculations. There are a couple of categories that are simply not included in the calculation even though they are specified in the legend. Now, trophy points is a meaningless thing and I wouldn't care if it were eliminated. But even if it is eliminated, the cause of the error should be identified and fixed. If it's a configuration issue with AAC, then that means that the same information is defined in two places and it is inconsistent. That's poor software design (which is not to say that even the best designed software isn't going to have such deficiencies here and there). So that is something that XenForo should make go away so that the information is defined in only one place within the configuration and all uses are keyed to that one definition.
  13. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,836
    1,308
    FWIW It appears that 'member rank' is weighted by both message count and tenure without regard to posting frequency (e.g. post counts being equal, longer-time members tend to hold higher rank) --- Just an, admittedly cursory, observation... :)
    Best regards
    HP
  14. JoeJester
    Apr 26, 2005
    3,392
    1,211
    There are various criteria in the "promotion" from new member ... all the options can be viewed in the manual at https://xenforo.com/help/manual/
    All the criteria set by the admin must be met, prior to the "promotion".
    I know this does not answer the specific question, but, it does illustrate that time and posts and even a likes to posts ratio could be involved.
    Only the admin knows the specific criteria, so if jrap is watching, inquiring minds want to know.
  15. BR-549
    Sep 22, 2013
    2,164
    415
    JoeJester,
    I have tried several searches on the manual link.
    I can find no information on this subject.
    What is the proper term for the text under the users name?
  16. tjohnson
    Dec 23, 2014
    618
    122
    I think JoeJester was referring to the section on User Group Promotions: https://xenforo.com/help/user-group-promotions/
    However, I don't think that's the applicable section, since it seems to be mainly referring to the permission levels that users have.
    I think the applicable section is the one on trophies: https://xenforo.com/help/trophies/
    It says:
    so what I gather from this and what WBahn is saying is that a user's title is based on his trophy points, but not all of the trophy points awarded are listed in the AAC Help (http://forum.allaboutcircuits.com/help/trophies).
    BR-549 likes this.
  17. BR-549
    Sep 22, 2013
    2,164
    415
    Thanks tj, but now I'm more confused.
    I guess I'll have to wait for a classical explanation. :D
  18. tjohnson
    Dec 23, 2014
    618
    122
    After looking again at several members' profiles, I'm beginning to wonder if the qualifications for Active Member are either to post 500 messages, or to be a member for 5 years.
  19. Wendy
    Mar 24, 2008
    20,772
    2,540
    Post count, off topic posts don't count.
  20. Hypatia's Protege
    Mar 1, 2015
    2,836
    1,308
    There are, however, "Active Members" with post counts < 500... However they tend to have lengthy tenure (join dates Ca. 2008)
    Best regards
    HP
