What makes a strobe light strobe?
Discussion in 'General Electronics Chat' started by Gdrumm, Mar 12, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I thought it was broken, but when I tap it on my workbench it flashes.
    I'm not sure if it is supposed to flash on it's own (I would think that it should).
    Anyway, I'm going to resolder the connections just in case something has come loose.
    Otherwise, I'm hoping someone sees a component in the pics that might be suspect.
    Thanks,
    Gary
  2. Gdrumm
    Aug 29, 2008
    684
    36
    The re-soldering worked.
    Interestingly, all the joints looked solid.
    Just goes to show you I guess.
    Next time I'll try a suspected fix before I post.
    Thanks,
    Gary
  3. BMorse
    Sep 26, 2009
    2,675
    234
    could you take a pic of the solder side?? only thing I can see which could cause what you describe is the potentiometer, could have a worn out wiper and when you tap it on the bench it makes the connection... or a broken solder joint :))).... a strobe should flash on its own once powered up, the pot should adjust the rate of the flashes....
  4. BMorse
    Sep 26, 2009
    2,675
    234
    sure, post as I am typing....lol glad you got it figured out.....
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    If it didn't strobe then it isn't a strobe light.
    t06afre likes this.
  6. #12
    Nov 30, 2010
    16,665
    7,313
    Lucky you. Once upon a time, I chased a bad solder joint in a TV for half a day. The only way I found it was with an oscilloscope showing 2 different wave forms on each end of a jumper wire!
    Nobody would suspect a jumper wire to be "bad", and there were way too many solder joints in a vacuum tube TV to "shotgun" the board. I feel lucky that touching the solder pad with the scope probe didn't make the connection work while I was measuring. I would have never found it! The simplest problems can drive you nuts. (One of the reasons I quit doing TV's.)
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Don't you have a Fluke #12 (the Fluke is actually called a #12).
    I've used one for years, it's a technician's multimeter that can can do beep continuity tests on tracks and wires in a live running TV.
    Enormously handy. :)
