What kind of transformer is this?
Discussion in 'General Electronics Chat' started by Chillum, Dec 5, 2014.
  1. Chillum
    Thread Starter Active Member
    Nov 13, 2014
    546
    9
    Is this valuable? I hope so 'cause I need a good one, and have been postponing buying one, got a customer account discount card at my local electronics store (fort777.co.za), 10% discount, but still, if I could harvest this! It's from an old UPS that just stopped working, now I checked for fuses, none that I can find is blown;
    say if you need more pics
    the battery is 12v, that means it steps down from 230V to 12V, yes? not much use then, have many switching 12V AC adaptors (wall warts)
    noob... how do I go from here? testing wise, without electrocuting myself
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    Looks like a standard 50/60 hz transformer, the red,white,yellow wires look like the input, and the others are the outputs.
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Ohm for the highest impedance winding and which wires are connected as other windings. Apply some voltage to the high impedance input and measure what comes out the other windings. I think Dave sees this as the output transformer, which would make the fat wires the input and some skinny wires the 230 volt output. I see it the other way. Some pair of skinny wires is the 230V input and the fat ones are the low voltage to charge the battery. If you can't tell the difference, don't even bother testing it. The results won't do you any good and you might get hurt.
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    I think there is a higher possibility that this is an inverter transformer that converts 12V up to 230Vac. The wiring will tell the tale.
  5. Chillum
    Nov 13, 2014
    546
    9
    It has to convert upto 230Vac 'cause its a ups power supply
  6. ISB123
    May 21, 2014
    1,240
    531
    What would you do with step up transformer?
  7. #12
    Nov 30, 2010
    16,705
    7,358
    When the power fails you chop up the current from the 12V battery and run it through a step up transformer to get 230VAC.
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    It's an Inverter Tx. If it is 12V one I think you can get around 7VAC or so but with center tap it could be more than that.
    U need to series connect the HV side to tht as a 220V to 12V one
  9. ISB123
    May 21, 2014
    1,240
    531
    Yeah I unserstand that but whats the use of it when you can plug stuff directly in the outlet and have higher current available. I would only use this transformer if I wanted to stay safe and not to play with high current.I'm talking about salvaging the transformer and not using it for UPS.
  10. R!f@@
    Apr 2, 2009
    8,793
    771
    There are times to use them like high current charger.
