Hi everyone , i have a question about a the circuit shown in the attachmens (prolem image)
Given :
1- the circuit in the problem image
2- the switch has been closed for a long time and then opend at t=0
problem :
get the current through the inductor before opening the switch
Solution :
making an equivalent circuit for t<0 as show in the solution image, treating the the inductor like a short ciruict then it wil carry all the current from the current source , so the current through the inductor is 5A (or -5A considnering the refrence arrow).
My qustion :
i have no problem with treating the inductor as an short circuit while t<0 but i can't understand why erasing the 40V battery and the 4 ohm resistor from the equivalent circuit ? if there is no battery in the original circuit then there will be a short circuit across the 4 ohm resistor then we can get it out of the equivalent circuit but the battery is there so why treating it like it is not there ? shouldn't it make an amount of currents that affect the current passing through the inductor ??
thank you
Given :
problem :
Solution :
My qustion :
thank you
