I've got a circuit where I'm feeding the output of a 230vac dimmer into a bridge rectifier and then the DC output of the rectifier is filtered with a huge inductor and a fairly large capacitor (I also have 2 inline surge limiting thermistors).
Anyway I got the circuit hooked up, tested it carefully and everything was working dandy. As a test load, I have 720 watts of incandescent bulbs - nice and bright. The highest I've had it up to is 150V across this load.
Since I had it all working, I wanted to measure the DC ripple and see how close I got it to what I modeled in LTSpice. So I got out my oscilloscope - a Tektronics 2215A that's been in a box at least 10 years. When I bought it (used) it came with 2 probes so I just grabbed one of them. I don't remember what the difference was between the probes. I attached the probe across the load with the red on the positive side and black on the negative.
As soon as I applied power, the probe actually exploded! The black probe popped off and flew apart.
Was this probe designed to measure current perhaps - so I just created a short circuit? Or is there something else that I obviously did stupid? I am certain that there weren't any wires touching - whatever short that was came from the probe.
Of course I shut off power right away, and then after checking things out I reapplied power with no probe. As soon as I started bringing up the dimmer from 0, the dimmer exploded quite loudly. The best I can guess is the original short damaged the dimmer.
Needless to say, I'll need to order a new dimmer and test the various components to make sure they weren't damaged. But I wonder if anyone has any insight as to what may have gone wrong? Its pretty obvious I did something stupid, but it would be nice to know what haha.
Here's the probe I used. The shroud is missing from the black hook because it blew off. The little black plastic piece where the red/black probes come out is stamped with the name "E-Z-HOOK". There's no model number, and the web site for EZ-Hook doesn't have this model - I'm sure its too old.
