What kind of motor is this?
Discussion in 'General Electronics Chat' started by droggie, Sep 22, 2013.
  1. droggie
    Oct 21, 2012
    137
    I want to replace this motor I took from a desk fan. Can anyone tell me what this type of motor is called?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    Shaded pole.
  3. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,508
    +1 on the shaded pole, single phase induction motor, recognized by the copper shorted turns providing phase shift.
    3 wires into the motor is not common, however?
    Max.
  4. droggie
    Oct 21, 2012
    137
    I'm guessing it's a POT.
  5. debe
    Sep 21, 2010
    955
    185
    3 wires are common in desk fans, one is neutral other 2 are for 2 different speeds, active switched betwean either one.
  6. sheldons
    Oct 26, 2011
    616
    101
    also we find these shaded pole induction motors with 3 wires in some microwaves used as the cooling fan for the mag....the extra wire being used to drop the supply and feed a low voltage turntable motor......
  7. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    I've seen some with a thermal fuse, what kind of problem are you having?
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    More likely a switch.
    Ken
  9. droggie
    Oct 21, 2012
    137
    The bearing will not turn. I tried lubricating it. It turns on, but just vibrates as if it's stuck.
  10. Metalmann
    Dec 8, 2012
    700
    223
    It's been several years since I worked on old record players/turntables, but most had those same SP motors.
    Did you happen to remove the bolts and nuts for the bearing housings?
    Or, knock them out of alignment?
    Try to re-adjust the linear bearing surfaces by lightly shifting the bearing mounts.
    Loosen the bolts very little, once the motor starts spinning, carefully tighten the bolts back down.
    The bronze bearings/bushings, do have some adjustment in both ends. Not much, though.;)
    May take you a few tries to get it just right.
    Droto likes this.
  11. Droto
    Sep 23, 2013
    9
    Why bother? Fans are $13 US at wal-fart, unless you're bored...lol
  12. Droto
    Sep 23, 2013
    9
    Metalman, you are correct. I will add that he / she should drown the (both if needs be ) bearing in a good grade of lubricant and spin it by hand a few times. MOST bearings now-a-days are "Oil-lees" meaning they are impregnated with its own supply of oil. If it still just "Sits-There"...the motor wiring is junk....IMO
  13. Gdrumm
    Aug 29, 2008
    684
    36
    Many times they must be disassembled, and the ends of the shaft cleaned with scotch-brite, or other mild abrasive. I even have a small tool that I attach to a drill, and clean out the bushings in the same way. Then lube, reassemble, making sure you can spin the shaft easily by hand, and it's usually good for another 20 years, (or 1 year if made in China).
  14. droggie
    Oct 21, 2012
    137
    One of he bolts striped and one of the bushing is missing. I'd try replace the motor, however these types of motors seem quite expensive.
