What kind of microcontroller might this be?
Discussion in 'Embedded Systems and Microcontrollers' started by Minuette, May 10, 2016.
  1. Minuette
    May 10, 2016
    Hi all!
    I want to copy this small circuit. It is a led flasher that also can have a steady beam. I'm told the only component probably is a microcontroller.
    My question is, what kind of small, and very flat, microcontroller (what type) is it, and if a regular guy like me can duplicate it with a "burner"? I did the quotes because the componant really looks like a small cheramic capacitator with 3 or 4 legs. I'm not sure.
    I am a total beginner with this kind of stuff, but i have been programming for +20 years, so with some study on the subject i'm sure i can pull it off.
    I just dont know what kind of microcontroller that little bump on the PCB might be?
    Here is a picture: https://www.dropbox.com/s/73934srk66166uw/IMG_0502.JPG?dl=0
    Thank you in advance!
  2. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    You probably can’t duplicate it easily. Commercial code will be protected, but it doesn’t matter.
    Let’s say it’s a pic 12C509A then (just an example with a built in RC clock).
    It wouldn’t take long to write the program you want.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    The ivory-colored blob may be a circuit on board (COB). That is, the bare MCU chip is on the PCB and covered with an epoxy-like blob. You cannot buy them in small numbers.
    If you want something really small, the 10F series at Microchip will fit that bill; however, I think you would be more comfortable with a 12F chip if this project is your first time with microcontrollers.
    John
  4. Minuette
    May 10, 2016
    Thanks for your replies!
