What kind of gate is this
Discussion in 'General Electronics Chat' started by gammaman, Feb 20, 2009.
  1. gammaman
    Feb 14, 2009
    29
    Code ( (Unknown Language)):
    1.
    2. Library ieee;
    3. Use ieee.std_logic_1164.all;
    4. Entity ThisTable is
    5. Port(
    6.     D: in std_logic_vector(1 downto 0);
    7.     Y: out std_logic_vector(1 downto 0));
    8.
    9. End ThisTable;
    10. Architecture Joe_Structure of ThisTable is
    11. Begin
    12. with D select
    13.     Y<= "01" when "00",
    14.         "00" when "01",
    15.         "11" when "10",
    16.         "11" when "11";
    17. End Joe_Structure;
    18.
  2. mik3
    Feb 4, 2008
    4,846
    63
    The function can't be described by a particular gate. The function of the code is a combination of logic gates if you build it with discrete gate ICs.
  3. gammaman
    Feb 14, 2009
    29
    Ok, so then what would the truth table be for this code.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Y<= "01" when "00",
    "00" when "01",
    "11" when "10",
    "11" when "11";
    You have it in the code, the bits after when are the inputs.
  5. kubeek
    Sep 20, 2005
    4,688
    806
    Actualy it should be two functions, its easier to understand:
    Function a
    "0" when "00",
    "0" when "01",
    "1" when "10",
    "1" when "11";
    Function b
    "1" when "00",
    "0" when "01",
    "1" when "10",
    "1" when "11";
